Is this an IHO issue in general, or just certain ROMs like Harmonia 2.05 and others?
IHO issue. I just saw it several times in the IHO thread - not in a long time, though. Did the fix work for you?
AndroidcentralNever heard of that.
I meant I have never heard of having to raise the min to keep the phone stable.Androidcentral
LeslieAnn 01:52 AM 04-23-2011
CPU overclock recommended settings: I wouldn't recommend going below 400mhz, we are finding it simply isn't efficient. If you tend to just listen to music and surf, 400 should be your baseline. Those who use navigation, play videos and/or Angry Birds, you may find 600 better as a minimum. If you find your phone getting warm during use, raising the baseline may actually help. No, I did not write that backwards, it's due to how the processor works. See this thread for more information: http://forum.androidcentral.com/opti...-part-2-a.html
Once you pass 480, the phone kicks up a notch in terms of power draw, the point of locking min to 480 is to try and keep from kicking up.
Yes some people probably would benefit from 600, but most won't and as mentioned in the overclock thread, you have to experiment if you want to get the very most out of things.
How do you disable the camera's shutter sound in Harmonia/IHO?The no audio in camcorder recordings is a known issue. To resolve it, disable the camera's shutter sound.
I know this comment is a little off the discussion, but after much trial and error and help from one of LeslieAnn's post on overclocking I have noticed with my OV the higher I overclock I have to raise the min CPU speed .My phone (min600/max825 MHz) no reboots. When I left the min at stock (245mhz) no matter how low I overclocked my phone would eventually reboot.Please chime in LeslieAnn with any corrections.Thanks!
i run 245/825 smartass v2 for the main, with 2 governors 245/245 priority 100 smartass v2 screen off and 245/600 priority 90 smartass v2 charging...incredible speed and battery life. since my phone is usually on lockscreen most of the time, this scenario works out great for me
never had my phone reboot or any fcs either for what its worth
I wouldn't change it just yet.
Wait for 2.06
