[ROM] Harmonia 2.09 18July12 (IHO Gingerbread)
I Don't have a select user agents option or any advanced options in the settings menu in the browser
Maybe try the Dolphin browser (from Playstore) . It has this function. I'm using the browser that is part of Harmonia 2.07. I just assumed it was same as stock. You can also download to your PC and then move to your SD card.
Reactions: _Severability_
Re: [ROM] Harmonia 2.08 19May12 (IHO Gingerbread)
Upgrade to 2.08 fixed the "missing shared library" issues from 2.07.
Thanks for the fantastic ROM Leslie Ann! :)
While I have never personally flashed this rom on my phone, I have flashed this on my girls V and she absolutely love it. Works flawlessly for her. No force closes or reboots in almost 72 hours. And while setting everything up on the phone for her, I must admit it was very smooth and responsive.
Thanks for all your hard work, it is greatly respected and appreciated.
Sent from my MiRaGe'D Optimus V
Which ext is required For Harmonia? And will it work automatically when Done setting it up?
Sent from my Cybertronian QuattrOV using Tapatalk 2000 (Now With Teleka-Typing!!!!)
If the question is what type of formatting should be used for the SDcard parttion, I would like to know the answer to this as well. Right now I'm running Harmonia 2.06 and have a 1GB partition for Link2SD to link apps to. The partition is formatted as FAT32 and seems to be working. Is that the best format to use or do one of the ext's (2, 3, 4) work better?
Thanks to all the great minds on this forum.:)
All of my 2.07 problems are solved with this new release. Thank you!
OK, I'm getting the "invalid package file" error, which I'm pretty sure is due to the fact that my davlik-cache was entirely full. "df -h" gives me the following; is that correct for this ROM or do I need to re-flash? Any recommended options for moving / linking the davlik cache to the SD card, or do I just need to live with not having as many apps?
Filesystem Size Used Available Use% Mounted on
tmpfs 212.8M 32.0K 212.8M 0% /dev
tmpfs 212.8M 0 212.8M 0% /mnt/asec
tmpfs 212.8M 0 212.8M 0% /mnt/obb
/dev/block/mtdblock5 164.5M 97.8M 66.7M 59% /system
/dev/block/mtdblock6 178.9M 108.4M 70.4M 61% /data
/dev/block/mtdblock1 110.1M 102.5M 7.6M 93% /cache
/dev/block/vold/179:2
988.3M 17.3M 971.0M 2% /data/sdext2
/dev/block/mtdblock1 110.1M 102.5M 7.6M 93% /data/dalvik-cache
/dev/block/mmcblk0p2 988.3M 17.3M 971.0M 2% /sd-ext
Wipe Dalvik, wipe the data for Google Play, that may help, but sometimes this is caused by a Play Store error. Don't go tearing your phone apart right away over it.
And once again, MarketFix is worth a try. Fixes a lot of these problems without further ado. Tiny program, takes literally two seconds.
Have tried the MarketFix and no difference. Trying the stuff LeslieAnn suggested (awesome ROM btw, love it despite the issues) - I guess my question is if 100 mb in the davlik-cache is normal... I've got a 32 GB SD card but it's not going to me a lot of good for apps if the davlik-cache is filled up with apps.
I use ext2 because it is the default selection when setting up Link2SD.
Hi, I'm new to rooting and flashing rom's so please be patient! I currently have cyanogenmod 7.2.0 and Harmonia 2.07 running on my Optimus V. I wanted to update to Harmonia 2.08 because I was having the apps not compatible issue as well. My problem is that I can not get into clockworkmod recovery. I have tried rebooting through recovery and bootlog (from the power button while phone is off), and I have also tried holding down the home screen, volume down and power button (while the phone is powered off), and all it will do is reboot into 2.07. What am I doing wrong???
As a side note, is there a way to stop my phone from completely rebooting every time it is powered off? It's a pain in the butt to reinstall all my apps every time I power down my phone.
Hi, LeslieAnn. Just went from 1.8 to 2.08. Again, excellent work! Thank you again for all the effort you put into giving us something that we can actually use without having to navigate through a maze of useless junk. :)
"package file is invalid" errors when trying to update apps from the market. MarketFix doesn't alleviate the problem, nor does clearing Play Store data. Doh!
Found out that thaunknownartist was using a theme that someone pulled from xda. Restored to my harmonia back up and bam! instant awesomeness with ics look (:
njira
