[ROM] Harmonia 2.09 18July12 (IHO Gingerbread)
I finally Downloaded this rom and flash it for the first Time! Its amazing!!!! The best rom I've flashed by far!
Sent from my LG-VM670
Re: [ROM] Harmonia 2.08 19May12 (IHO Gingerbread)
I honestly think this ROM is perfect as is, its been my daily since ever, I am happy. Thanks for all your work over the past few months! Any update past this is just pure goodies I would assume. (:
Reactions: topdawg661
Thanks again, been running 2.08 for three weeks now, very solid rom. Recently tried to install "cartoon wars 2" and I got an error of insufficient space. Although it is a very large game file I did have enough room for it, so i tried "marketfix" that fixed the original insufficient space error and surprisingly the only missing market app podkicker is now available again.
Reactions: diecastdonkey
I'm gonna flash on my s for the heck of it. It sounds like a good rom
Sent from my LG-LS670 using Xparent ICS Blue Tapatalk 2
OMG I GOT IT WORKING! Runs like a dream gotta switch kernels for buttons but awesome! Just found my new daily rom!!!! I'm on the optimus s gotta change my signature lol
Anyway I can make it have the menu and home switched to the optimus s button layout?
You can fix it by undoing the script in iho that moves Facebook cache to the cage partition. You'll lose some internal storage but if you keep everything moved to the sdcard it should not be an issue.
http://forums.androidcentral.com/showthread.php?t=179865
Market/Play Invalid Package and/or Insufficient Space fix CM7
Thanks
Harmonia
806 MHz
some kernel
amphetimines
If you take the system/usr/keylayout/thunder_keypad.kl from an OS GB rom and replace it in the Harmonia zip file before you flash, that will fix the button layout. Otherwise there is a button remap tool in the Play store.
I would think there is a similar rom for the OS though.
I LOVE this one THOUGH
Sent from futuristic optimus s
Anybody else experiencing White Bar Syndrome? Every time I leave the house, the wifi and data bars go white. No connection, even though bars are showing. Reading up, it sounds like it's a matter of being connected to Google's servers or not being connected. Blue is good, white is not. I don't think it's a ROM issue, but since it came on all of a sudden, figured I'd check to see if it's commonplace.
VM has been having some issues lately, probably the new servers and possibly load from the Evo V. Most likely the new server though.
Makes perfect sense. Thanks for that. I'll just wait it out. Sometimes toggling airplane mode on and then off fixes it up.
Just had to say I appreciate this very much. I was so losing patience with seeing "low on space" after OTA updates and having to dig into my apps to see what I could do without. I was considering springing for the EVO V, so you likely saved me $300 or at least delayed it. This is the first rom I've tried for my Optimus V and it is just what I wanted, "No Bloatware". I replaced my Sprint HTC Touch with this LG. Yeah, I held on to it far too long. I tried several different roms from xda on my Touch, both Windows and Android but couldn't get what I wanted. I think this may be it.:)
Still having reboots and freezes when I use the navigate (google maps) program. Anyone else experiencing this? I tried reinstalling maps, but nothing changed.
Sometimes Fix Permissions will help with that. Easy enough to try, anyway. I find Google Maps troublesome in all sorts of ways.
marik999
