[ROM] Harmonia 2.09 18July12 (IHO Gingerbread)
Now the insufficient space error is in fact due to running out of space in the internal data partition. People wonder why they can't install a 7mb app when they have 10mb free.
The reason is because they need at least twice that space if not more. The app has to first be downloaded before it can be installed. Once installed the original download can be deleted but it still needs the space for the temporary storage.
The fix for this is to move the download storage area to the sdcard. I'll find a link to that thread later when I'm on my computer.
Re: [ROM] Harmonia 2.08 19May12 (IHO Gingerbread)
I can almost always overcome that error with MarketFix. It must do something to that effect. Doesn't do Jack for the package file error, though.
Yes that's exactly what market fix does. I just find it easier to type a few lines into terminal emulator than to install another app.
will there be a new Harmonia? or are there any updates for this?
Was the mms fix for CM7 ever (back in feb) ever incorporated into Harmonia 2.08? Because i flashed over from Harmonia 1.xx and i'm having mms issues.
I have an OV. Also I find it curious that in the CM7 Rom you can't edit APN's? At first i thought my problem was just with the APN's, but now im not sure.
I wonder if my google maps crashes are due to using link2sd with maps? As a test, I've changed maps from linked to the regular apps2sd. I'll report back whether that stops the crashes.
Also note that the backup program that LeslieAnn mentioned, mybackup root, does not work right with apps linked to the SD card. Titanium works fine with them though. I don't know what happens with linked apps in a nandroid backup, but I suspect they are not backed up (but may be available if your sd card is intact?).
MMS works great in all of the IHO ROMs. Just be sure you are doing a full wipe.
Interesting, I'm finally reflashing my mom's phone as it has been having issues after a restore, and i install 2.08 and the Play store ins't accessible! I don't know why, i've tried 3 times (with 2 different downloads of it) doing a full wipe and no luck, then I tried 2.07 and the same problem! Help?
Just to add.... Area code is required for mms to work
Sent from my VM670 using Tapatalk 2
But the guy futher up flashed CM7 over Froyo without a full wipe. Its recommended to do a full wipe when coming from a different Version.
Does anyone know what theme is used in Harmonia? I love the cyan colors. And I can't find a theme this color that changes the status bar icons that color as well.
Its called Cyanbread I think. Its CyanogenMods default theme.
Is there a quicker, more convenient to switch to this from BACKside 0502 with all my apps intact and relinked? The last time I did this it took literally 6 hours.
Rtisokjoala
