[ROM][ICS][Aug 18, 2012] Android Open Kang Project [Stable 4]
Status
Not open for further replies.
Re: [ROM][July 30, 2012] Android Open Kang Project [Stable 2]
Storage FC? That is not a known issue :confused:
Yeah, I guess it's only happening to me. (not being sarcastic) Like I said I can access the files just fine through a file manager, but that's it. Not only that the ROM renames the SD Cards to SDCard1 and SDCard.
External SD Card doesn't show up, files cannot be accessed outside of a file manager. the storage option in the settings menu FC's immediately upon clicking on the option.
Wipe dalvic cache.
Had the same problem and that fixed it right up :)
Sent from my SPH-D710 using Android Central Forums
Wawo (bad imitation scooby) :p
New stock. FH13 :D
Ur cool DK, :cool: ur cool man
Sent from my SPH-D710 using Tapatalk 2
Re: [ROM][ICS][July 30, 2012] Android Open Kang Project [Stable 2
If anyone wants to test a new ported version of MS6 here ya go:
AOKP_M6_S3_20120816_PORT.zip - 4shared.com - online file sharing and storage - download
Please be aware you are flashing this at your own risk.
Please flash from el26 w cwm5 recovery. If you use any other recovery or ics recovery may god be with you. If you brick as a result I will laugh at you.
Wipe data
Wipe cache
Flash rom
Flash gapps
Reboot
I'm sorry DK what does the MS6 mean? Is this just an update to stable 2? I've been away for a bit
Wipe data
Wipe cache
Flash rom
Flash gapps
Reboot
May I ask why el26? I've always used el29.
anybody know what's new in this rom? which kernel is it running?
Wipe data
Wipe cache
Flash rom
Flash gapps
Reboot
I'm trying to flash it now, but it's stuck at the boot animation. Been this way for about 7 minutes.
as soon as the download finishes i will be able to let you know if i can get it to boot into rom. excitement :D this rom is my daily driver, i'm so eager for it's next installment.
Status
Dave7
