[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
Nice work. Anyone get roboto font on here? Downloaded superuser and font installer from the market,font installer says I don't have root access.
Sent from my Nexus S 4G using Tapatalk
surprisingly EACH & EVERYTHING IS working! Nexus S i9023.the only thing i'm dying for is Face Unlock.
I am using that DG guy's ROM
This is truly exciting! Having a working version of Android 4.0 on my device before the device touted to be the first to run it is available! Beezy I appreciate what you've done greatly! Thank you so much!
I got it working on my I9023 by disabling SIM check... Now I have network for voice, but still not mobile data over GSM/3G... (But WiFi is working)
Its because on our i9023 under phone information menu (*#*#4636) menu its stuck on GSM/CDMA and even if u change it to WCDMA it just changes right back so just needs to fix the bands and data might work?
tested it on my Nexus S 4G and I haven't found a problem so far! (even wifi is working!)
the only thing is like everyone has said panoramic doesn't work, and camera app crashes (but I just pressed "wait" and it worked).
will post anything else :)
*edit*
oh yeah and I can't seem to root it.
also menu button doesn't work. (doesn't put up the menu.)
I tried flashing it on my nexus s 9020 and i got an error message.
Should i try flashing the netarchy first?
I would rly like to flash it so help would be aprechiated! ;D
Greetings!
@beezy, great work man, i'm humming along on my NS4G and I have to say, for v2 this is awesome!
Obviously a few minor issues but phenomenal work.
thanks a bunch!
Menu works normally in apps, but does nothing in the launcher. Also, long press menu controlled show/hide keyboard in GB, would be nice to get that back. Thanks again!
Titanium doesn't work. It fails if you restore one app, and it thinks it worked with batch restore, but it doesn't install any apps. Installing them manually and copying over all the app data will restore them correctly, but it's a pita :p Restoring all my apps took me over an hour lol
I tried installing just the wallet apk and it ran, but for some reason I can't enable nfc.
I tried both matrix and apocalypse kernels and they hung at the kernel boot screen.
Wonderful job!! This is a nice smooth rom!!! I'm gonna use it for my daily :) You should register it with ROM manager so we can all stay up to date on the builds!!
This works much better than i expected it to work. Very well done guys. :)
I have a stuck sync icon, even when sycn is disabled, and returns after a reboot. Anyone else?
Okay, I am now running this on my Nexus S 4G. Will post anything I find interesting (starting with WOW ICS is nice to look at).
If anyone figures this out, I'd love a solution.
Agreed x 100
Status
redmercer
