[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
if im not mistaken google released the SDK right after they announced the new nexus.
so thats how the SDK came about, as for getting it to run, somehow gingerbread files are involved to patch up some things.
The image I posted was from a pre SDK leak. and these are not gingerbread resources, they're either from honeycomb or an early (pre-sdk) build of Ice Cream Sandwich. Unless there is something about Gingerbread AOSP that I don't know
Did you get this build from Google somehow??
This is seriously driving me crazy, I have no idea how you did this if you did this
What is it you're getting at? He got it from the same place everyone else did & he's been up for 4 days trying to get it to work.
+1 please anyone know? Can we flash back to previous back ups?
Yes your recovery is still there,you can restore nadroid and flash roms.Full root is going to added SU app and everything else.A lot of sleepless night you forget about the small things.lol
gsm other versions of nexus i need a little sleep before messing around with the files for you:'(
besides losing root & not being able to use TB, ROM man, or super user the ROM is fine. a few bugs here & there, but a great start nonetheless. I'll definitely be keeping my eye on this bkuz I know y'all will have it humming in know time. *tips cap*
Great! Does your finding also enable you to create an i9020T/i9023 version?
got it functioning on my nexus s 3g fine on at&t. will post download at my drewgaren.com site and link back here. I will try and improve on this for Nexus S 3g as well. So far so good.
Just saw that you've updated your site.
Downloading!
EDIT: Still booting. But as it booted, my computer came up with "Google File-CD gadget"-drivers. Does anyone know what it's for? I can't find any info about it on Google.
EDIT2: It's pretty damn smooth! I can confirm that I can send SMS and make calls, but I don't know about 3G, as I had some problems with it before this ROM. Wifi doesn't seem to work Scratch that, it works just fine! But at least there are delicious rotation animations!
T9023
Actually can someone double check their wifi mine is working now and it wasn't before i have a ip lock now.lol
Just asking one's with the NS4G only need two replies.thanks
Downloading!
EDIT2: It's pretty damn smooth! I can confirm that I can send SMS and make calls, but I don't know about 3G, as I had some problems with it before this ROM. Wifi doesn't seem to work. But at least there are delicious rotation animations!
i'm still downloading.
for wifi to work you need to install netarchy kernel according to his instructions here DrewGaren.com
for 3G i guess you need to input APN on your own?
As I said, it works fine without any extra kernel. No idea why.
I've had that problem with 3G for a few days (not only ICS) and I've tried everything I can think of, APN included. The only thing I need is to call my carrier and ask if they have problems with 3G in my area or something. I think it's a hardware problem...
so the wifi works fine without netarchy kernel?
Status
Sonfollower28
