[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
Has anybody played around with the camera on this rom and had any issues????
The camera somewhat works. It tends to crash, but I've taken pictures and recorded videos with it.
I can use the Panorama mode, but I can't save the picture, as it doesn't react when I press 'OK'.
mine seems to stuck at google logo for quite sometime.
on nexus s.
Don't you have an I9023?
I'm not sure, but I think the beta2 you downloaded at DrewGaren.com could be only for I9020A...
(Can someone confirm?)
EDIT: Sorry for wrong information: MrHaxx1 has is running on I9023...
yes on 19023, rebooted now, will setup in alittle bit. :)
update: restoring data now.
this is build 13, right?
therefore we have old icons and face unlock missing?
any solution to get newest build 14?
So, just to sum-up:
Nexus S i9023:
-WiFi connects but doesnt work.
-Calls/sms work, but no data
-If flashed Netarchy Kernel, stuck at boot logo.
This is my XP, so mileage may vary.
So, just to sum-up:
Nexus S i9023:
For everyone with WiFi problem:
1. Try to connect to your network - it will most likely not work.
2. Disconnect and forget the network.
3. Connect again, then it should work.
That's what I did anyway, and it works just fine.
Also, I get decent performance in Cut the Rope and Google Earth, though it's better on GB. Just thought I should say this.
EDIT: Surprisingly enough, 3rd party keyboards works without problems. Only tried SwiftKey, though.
Ya that worked for me to fix my wifi when i flashed this earlier.. So it sounds like that method would be the way to go to easily fix that issue.
Status
Sonfollower28
