[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
I can't push the notifications panel back up after I pull it down. I have to use one of the soft key buttons to exit out of it
Sent from my Nexus S 4G using Tapatalk
I had similar issues, it's kind of intermittent though, sometimes after restarting it won't go back up and then magically it will start. not too much of an inconvenience though.
with the same like four repeat questions over and over for the last several pages, I'm half tempted to write up an FAQ for the main post. Sadly, I know that the same people wouldn't bother reading it so I don't think it'd be too helpful. Thoughts?
I was about to ask beezy if i could, then he could put it up on the first post. But, I don't think anyone would read it either.. :(
First of all, want to give thanks to Breezy, War attack, and all devs on this. Second, Been running since yesterday and I have to say this is awesome. Been a long time MIUI rom user, and the best compliment I can pay u guys is this will now be my new daily driver. Let me know if you need testers for future releases. Keep up the GREAT work
It's okay i plan to change the first post up and make it so if you don't read the whole post you might not find the link and it should cover works/doesn't fully i've just been throwing it together.
Reactions: justmerob
lol, It's Beezy not Breezy
Beezy, I'm going to take a wild guess and say you have had success decompiling and recompiling the framework-res.apk or SystemUI.apk?
I've already gone to work doing some theme work but unfortunately I can't get Apk Manager 4.7 or 4.9 to re compile the either. I even updated my APKTOOL to the newest version from Google which I felt was the first problem.
Edit: Note, I attempted a re compile as you should before making any changes just to see and untouched it won't recompile for me :(
Still a no go...
Firstly - awesome job Beezy. This is a great starting point, more fully functioning than some CM7 nightlies:p
Second - Anyone able to drag down the notification bar while on the lockscreen? That's a feature I'm really excited about with ICS.
Found another keyboard issue
I'm unable to open anything in the SwiftKey menu besides the faq that opens the browser, thought id mention it, you can click away but nothing will open.
Can't change the theme either.
Just a heads up,
Sent from my Nexus S 4G with Ice Cream Sandwich
I just signed up to say, hell yeah!
I've been waiting for this update, and your rom will curb stomp my ice cream sandwich cravings for now! :p
thanks man! Huge props, keep it up Beezy!
Reactions: beezy
Quick question Beezy is there a way to add more screens? Like home screen when your scrolling from side to side
I've updated my newest beta version for Nexus S 3G that is a modified version Beezy's rom here. It will be on my site later tonight, currently I'm zip aligning and optimizing for a smaller system. I have new ics fonts all pulled from the sdk. optimized nexus prime audio files, the nexus prime boot ani installed, updated the ui and some apps, updated the build.prop, include superuser (root), updated the framework, updated the launcher and wallpapers to nexus prime walls, updated 3g data and gps location works, wifi also works with no problem. NFC currently is not working in this build but I am currently building it up for the next build. I will have beta 3 on my site around 10pm eastern time if you guys are interested in a Nexus S 3G update from me based off of Beezy's work. visit drewgaren.c
om
Drew how long roughly is that please its 1.30am in UK so will it be bout 3.00am it's released?
I've updated my newest beta version for Nexus S 3G that is a modified version Beezy's rom here. It will be on my site later tonight, currently I'm zip aligning and optimizing for a smaller system. I have new ics fonts all pulled from the sdk. optimized nexus prime audio files, the nexus prime boot ani installed, updated the ui and some apps, updated the build.prop, include superuser (root), updated the framework, updated the launcher and wallpapers to nexus prime walls, updated 3g data and gps location works, wifi also works with no problem. NFC currently is not working in this build but I am currently building it up for the next build. I will have beta 3 on my site around 10pm eastern time if you guys are interested in a Nexus S 3G update from me based off of Beezy's work. visit drewgaren.com
Awesome will this work for us 4G nexus owners?
Or be you post both versions?
Status
PmGs
