[ROM] ICS SDK Port [WIP]
Status
Not open for further replies.
keep something in mind people "this is ICS" some apps havent been optimized for it yet and may not work or will be buggy.
oh and thanks beezy for putting this together ;) ive been very busy and would not have the time to work the issues.
The problem with Wi-Fi, at least for me is the "Wi-Fi Connectivity Checks" option being enabled. once disabled Wi-Fi works and connects just fine
Hell
yes its a little buggy!
3g is weak can't wifi but I'm loving it! great job twitter me on lad.
Wifi works for me. At one point I thought it wasn't but I found out it was my router lol. Reset it and it picked it up. Nexus S 4G is my play phone until the actual update comes out. This was good enough to take it out the box. Using my Epic Touch 4G now.
I'm definitely getting the Galaxy Nexus when it.comes out for other carriers , because even though it's fun to play with on my NS4G, the screen is so small coming back to from a 4.52. A 4inch screen felt comfortable at first but now.
I also notice the magazine look for the contacts dont look all that high res. Much better then before. It'll look better on the GN I'm sure since the resolution will be higher. The contact would need a good resolution sized picture as well. Otherwise it'll stretch it out forcing it to look granny.
it is because your contacts photo is not hi res. you have to replace it with hi res photo suggested in ICS SDK.
Tyler, I flashed your zip and booting was very slow afterwards. Eventually started bootlooping, and I had to wipe & start over. I had already done font and root tweaks so maybe the duplication screwed it up, not sure what happened.
Just out of curiosity, did you pull fonts/bootanimation from the SDK or just gather ones already posted?
Thanks for putting that together!
Status
tahirmehmoodkhokhar786
