[ROM][ICS] the GODZILLA ROM 10-20-12
Re: [ROM][ICS] THE GODZILLA ROM tweaked and themed cm9!!!!!!!
Where can I download the latest Godzilla and where can I find the v6 supercharger I am hearing about?
Maybe you should try looking.
Maybe you should not be so rude.
The Godzilla ROM can be found in the OP of this thread. As far as the V6 supercharger goes, the search isn't turning up anything right this second, but I believe that this ROM already included multiple speed tweaks, I'd imagine that you won't gain any speed by flashing the supercharger on top of it. Good luck. :)
Any suggestions on getting wifi tethering to work? I can select it and it acts as if it will work but it turns off wifi and greys out check box so that I cannot uncheck. Just installed today.and am loving it so far. Fast and smooth!
Thanks!
Thanks!
I think everyone is using barnecual miss spelled
As far as I know, its already built in.
Hey, I'm trying to install Build 3-1 and its giving me an error
"E:Wrong digest:
System/xbin/openvpn
E:Signature verification failed
Installation aborted."
Any idea what i can do?
I'm coming from Harmonia 2.8 and I did a full wipe. (after backing up of course)
Any help would be great.
Also, the only build available right now is 3-1 but my brother has a downloaded copy of build 3-5. Why is it not available? Is there some really bad bug in it? I'll try installing it anyway as 3-1 isn't working.
Help would be greatly appreciated :-)
"E:Wrong digest:
System/xbin/openvpn
Disable sig verification :p:p
looking for good keyboards??
visit
jonskeyboards.com
this is really intriguing, i would love to test with my zvj as u already know ;)
Is it me or is the usb mass storage not working. please help
I'm having issues with dsp manager. It comes up but no impact on sound. Ideas?
mrtalha
