[ROM][ICS] the GODZILLA ROM 10-20-12
Re: [ROM][ICS] THE GODZILLA ROM tweaked and themed cm9!!!!!!!
For people having issues with ics roms hanging/rebooting, set your minimum clock value to 480. I have not been able to use ICS since the first quattrimus alpha, but once I changed that I have had literally zero issues on every ICS rom.
Reactions: jonny5449
Thanks for clearing that
@everyone
Here's a vote by Wednesday I will decide to remove translucency or not cast your votes
Also what ever launcher is not included in jb will be included in here maybe
Sent from my LG-LS670 using Tapatalk 2
If you remove transparency, there wouldn't be much of a difference from regular ICS. So keep it. Or eslse it wouldn't be considered theme eitherv
Exactly what I said :)
But honestly, if you update, you SHOULDN'T use old Framework and old SystemUI. You should decompile the SystemUI and add transparency manually.
Reactions: sellers86
Hi, Im ising a v and I flashed the rom about 20mins ago, the only problem im having is that wifi will not turn on. I reflashed and got the same results. There is no service on the phone so wifi is the only data connection that is uses. Am I the only one with this problem?
Yes. Redownload, then wipe everything and reflash.
Sent from my VM670 using Tapatalk
Sorry, tried everything. Wi-Fi does not work on current build, plus minor issues. Please take a look. Thanks.
Will look at it after school
:D
Wish I could still close sentences with "after school" lol. I turn 30 today and miss those days like crazy! Don't rush those years bro.
I know right?!? Im turning 24 in 3 months, not as old as Rudeco there but I still get what he is talking about. Also I redownloaded, wiped, wiped cache and Dalvik, reflashed rom and gapps, still get the same result of no wifi
Now that I'm officially 30 we don't use the term 'old' anymore buddy, lmao, we say ' years wise' lmao. :p
Happy Birthday.... Had mine on the 7th.... The big 38.... Weird thing... My wife has been 29 the last 4 years...
Sent from my VM670 using Tapatalk ? to here.
Reactions: Rudeco
Seems like my network speed slowed down out of nowhere apps in the store load slow and sometimes the store would time out
Aravol
