[ROM][ICS] the GODZILLA ROM 10-20-12
Any news?
On releases
Will sync with bobzhome latest cm9
Found a cool tweak that speeds up your phone quite a bit
This is about at its tip as cm9 development from cyanogenmod has stopped
All I can say is maybe two more updates then we will say hi to a need breed of Godzilla :screwy::what::what::);):cool:;););););)
Sent from my LG-LS670 using Tapatalk 2
Re: [ROM][ICS] THE GODZILLA ROM tweaked and themed cm9!!!!!!!
So when can we expect this new breed
wait so that means panorama camera works? im confused...
OK people updated OP with rom that works until I figure out source of wi fi problem use that one thank you as for s user wait for tomorrow so I can report it
The new breed will be coming :what::screwy::screwy::screwy::screwy::screwy:
Reactions: Malaci
I had a user saying he had problems with ringtones and notification sounds anyone else experiencing these problems???
Looking for good cm9 or cm7 themes??? visit this site for good themes. Digital House of Treats • Index page
Did anyone else have this problem? Everytime I try to assign a ringtone to a contact it still continues to use the phone's default ringtone. Please Help! Thanks!
So far no problems, Wi-Fi is working and everything is running smoothly. Cant wait for new breed :P
Neither can I :thumbup:
Will be a little while for sure
for wifi, try replacing wpa_supplicant in system/bin with quattrimus's
is there a way to change transparent status bar
the only issue i'm having is that the hard key backlights won't go off, I heard about a fix for this, but I don't remember what it was and my searches aren't showing up with anything....
That's a prob with bobZ rom
The new Godzilla boots but not done yet will be releasing soon :cool:
Arwen
