[ROM][ICS] the GODZILLA ROM 10-20-12
Re: [ROM][ICS] THE GODZILLA ROM tweaked and themed cm9!!!!!!!
Will look at this
Sent from my LG-LS670 using Tapatalk 2
all you would have to do to remove boot sound is get a root explorer, go into system/media and delete android_audio.mp3 or something like that.
You also need to add a certain setting into a script or like Seller's said, ' Something like that '. I have no idea how to do it myself.
As I might
I ran across a zip that enables boot sound on cyanogen mod maybe it will work for cm10 meaning its optional
any fix for the phone app crashing when making/receiving calls? had to stop using this ROM because of that...
It works, yes. I just don't know how to add it by default. I remember checking the zip a long time ago and it was a file inside like:
Boot sound.sh
I don't really remember.
A few pointers
- Check your tweaks, copying them for the original Godzilla rom is really bad. Everything becomes outdated.
- Your Tweaks you added aren't ALL there. Your missing files in the Lib, Bin, and usr folder.
- Take Bobz, or TDMs rom, and add the tweaks by getting them from the source.
You then add the build.prop tweaks by exploring the flash able zip with the tweaks you want to add. ;)
Reactions: jonny5449
I would just edit the zip with sound of choice and people can flash it
I really wanna try this out! Just not sure yet if i can part with the customization options that AOKP offers. Still, either tonight or this weekend i may take it for a spin.
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
I have a cm10 version on vmroms just test builds
Reactions: dingermtb
Looks like with the 3 day weekend coming, and some of my own theme elements, i'll have ZombieZilla 4.1 :D
This rom with be looking more like jb very soon
Why did you close down the thread on vmroms?!?!:confused:
Yes sorry I will theme this really hard to look like jb
Dang that will be cool. It sucks cause you could have done so much with that cause this ROM is amazing.
Oh don't worry I plan on building my own jb well I will try then we say yah
I have a new build but screwed up keyboard will prolly release Monday as tomorrow is dedicated to setting up my Linux build environment
Reactions: joerivera17
gruptysh
