[ROM] Incredibly Re-Engineered v2.3 [02-8-11] Fast, Beautiful, and Simply Magnificent
This rom is definitely incredible. had it for about a month now, and just did the update. awesome. two things i noticed.
followed instructions to install the rom to a T (wiped everything etc...). my gmail and market are not translucent (no big deal - just an observation) Everything else is perfect. 2nd thing is (and this one matters to me) Set my alarm for this morning at 8 am. Alarm went off fine at the correct time. I picked up my phone (screen was off), pressed power button to turn on screen. at lock screen, I unlocked the phone and there was no way to turn off the alarm. I tried everything, I mean EVERYTHING! Finally I had to shut the phone down to get it to stop alarming. I tried again later today and the same thing happened. Anyone have the same issue or have a way to turn the alarm off? Thanks.
I thought I read something about this alarm clock issue, I thought It had something to do with using the sense alarm clock verses the non sense alarm clock.
I couldn't get this rom to flash for me so Im not using it, but you might want to look into the sense/non sense alarm clock
Good Luck
Ken
Read the first couple of posts here...
[ROM] Incredibly Re-Engineered v2.3.2 [02-25-11] - xda-developers
The answer is in post 4.
Ok so I flashed the gingerbread theme and I like it however I am not able to change the icon in the launcher. It always has the browser icon even when I change what goes there. Any ideas.
I wanted to reinstall this rom so i redownloaded it wiped all but when it was installing i got this error
amend scripting (update-script) is no longer supported.
amend script was deprecated by google in android 1.5
it was necessary to remove it when upgrading to the clockworkmod 3.0 gingerbread based recovery.
please switch to edify scripting (updater-script and update-binary) to create working update zip packages.
Installation aborted
So I researched and found that i had to backdate CWM but when i went into rom manager i only saw 3.0.0.8...7...6..5...Where did all the older versions go?
Anyone have a solution? THANKS
fixed this issue thanks to pville....but does anyone know how to get the rotary lock screen once the gingerbread theme has been flashed...there is an option for it but when i hit it i get no change
anyone having issues updating Google Maps. I have this ROM flashed and it has been amazing. Tried updating Maps and keeping getting an error on install that the "package was not properly signed for"
is this an issues with the ROM?
love this rom its so quick i have an hour and a hlaf up up time and 20 mins awake time and 99% battery using chichitech 1800 battery is this possible?
using the kernel that came with the rom
also anyway to get a droid style lock screen you know the ones that go left to right? i hear people say vanilla i thought those are vanilla
Also I don't have MMS port or proxy settings I haven't been able to send a picture messge in over a month since I started using custom roms.....why?
Sent from my Incrdible using Tapatalk
yeah im haveing the same problem
search the xda thread and look for my post on how to update maps
Thanks Chingy, I'll check it out when I get home from work tonight. Appreciate the Dev. Reply for this.
I'll be sure to read it through so I don't pester with more questions about it.
i love this rom but im having an issue with my wireless tether running slow and i get a lockscreen force close everytimre the phone loads up
Ok so I have a stock dinc and want to use this rom .. can someone please give me simple step by step instructions on how to do this. I have watched videos and they always seem to miss a step or out of focus and you can't see what they are doing. I use to have a storm 2 and that was much easier to hack ..lol you can email me at momof1grl2byz@Gmail.com thank you so much for the help!
As was the case with my Fascinate a few months back, flashing this ROM to my Incredible has brought the phone back from the brink of ebay. So I definitely want to say thanks (as I did in the original post)!
Download the 2.3.2 ROM in the OP of this thread.
If you download it on your phone the browser will put it on your SD card in a folder called /download
Follow the Flash from Recovery directions in this post
http://forum.androidcentral.com/htc...oot-rom-your-droid-incredible.html#post628102
Be sure you do a backup in recovery before you flash and wipe data, cache and dalvik cache.
You should be good to go.
Sweet ROM, But just seems like alot of freakin work just to get some typical stuff to run again on your phone... I cant stick with it... other than the issues, it is pretty sweet. I gave it a good shot though :)
What are you having problems getting running?
just little things. nothing major... having to dig through /sytem/apps just to get certain things back on my phone... i would rather have them on there and get rid of them than to have to go digging for them... I just guess I love another ROM more ;) but this is a sweet ROM... second favorite
athegn
