[ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
Glad to see the phoenix build is up. I shall go and say hi to it.
I love the new recovery. Big change over what I was using.
Sent from my LG-P505 using Android Central Forums
Haha told ya you'd like it :D
What exactly is fixed in that ROM, anyway?
Sent from my LG-p505 using Android Central Forums
Fixes a ton. Sound is fully working, new CM10 boot animation, semi fixed grid, and there is a lot of behind the scenes stuff too.
PS Here is my revised version of the main post:
Cyanogenmod10, Jelly Bean 4.1.1, Compiled from Source
A number of us have began building jelly bean. I will be working on builds for the Phoenix while Rashed will manage the Thrive builds. Arjen will be around to help us when we need it. These builds are experimental and are NOT ready for daily use, CM10 is still in it's very early stages. Many things will not be working and many things are not yet implemented. Now onto what's working ^_^
What works:
- Wifi
- All Radio's, Including data
- Graphics Acceleration
- Audio
- Bluetooth
- Google Apps using the 7/26 GAPPS build
What doesn't work/ What's broken:
- Camera
- Google Now (Working on a fix)
- ALOT of other things.
_________________
DOWNLOAD:
All builds will be within my Google Drive and my Dropbox.
P505:
Google Drive:https://docs.google.com/folder/d/0B8...xibjBaeW8/edit
Dropbox:https://www.dropbox.com/sh/jsco6ek9eig99no/nEAX9BhWEV
P506: (Handeled by Rashed)
Dropbox: https://www.dropbox.com/sh/cy8sxg62ughwol4/Z8QiJ2zOvb/CM10/P506
Misc Downloads:
GAPPS: Goo.im Downloads - Downloading gapps-jb-20120726-signed.zip
______________
Screenshots
Weird... It's working for me and Oathkeeper
Which Gapps are you using? the 7/17 or the 7/26?
At first I used the 26 but just now I flashed the 17, but it still fc's. Should I factory reset?
I think you should have done a complete wipe. Cache, Dalvik, and battery when installing the rom. It's also good practice to reboot the phone between flashes. You can cheat that just by rebooting the recovery.
Hey Rashed, the new cwm only works for lp506 or 505 roms right? I tried flashing arjens cm9 and it was a no go. Any advice forum?
Only thing I know to do is to modify the updater-script in the rom you want to flash. Look for the assert() at the top of the file and make sure that there are entries in the getprop() for p500, p505, p506. Check out this thread
If u check a few posts back, I think he posted one for the thrive as well as the one for phoenix
I am pretty sure the CWM should install most ROMs but I'll take a look tonight ;)
Fixing up Catapult and preparing for another build :p
How to flash the p506 jb rom?
Sent from my LG-P506
Download the ROM to your SD card
Download the Gapps zip to your SD card
Reboot into recovery
Take a backup by selecting backup and restore
Select backup
After its done go back to the CWM main menu
Use the install zip from SD card option
Select the ROM zip file
Tell it yes you want to install it
Let it do its thing
Install the Gapps zip the same way
Reboot
I just restored ICS because of too many problems, namely: home button doesn't work, lock screen does not work either, the browser doesn't work, and notifications don't seem to work.
Ok I found a problem with Rashed's P505 CWM, when I backup its not generating the MD5 sums, which is VERY important. I can't restore them now. Is anyone else getting this problem?
Sent from my LG-p505 using Tapatalk 2
Will that affect installing the ROM at all? Because I restored something before and it worked fine.
Sent from my Amazon Kindle Fire using Android Central Forums
MO Shm0
