[ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
Re: [rom][cm10][jellybean][4.1.1][experimental][wip]
Building for P500 now. This might have some more working stuff....
It seems wifi isn't fixed :( Sorry guys, we will try to fix it though!
Wow....just wow...I think LG phoenix/thrive is getting supported from you wonderful devs more in the last couple of months than the sum of 14 months before that...
Please indicate when you think the phone is OK (only ok, does not have to be perfect) for everyday use - fairly stable, no dread battery drain etc.
Thanks!
EDIT: no camera is ok, no wifi is NOT ok =)
Guys use apex launcher or nova launcher as a replacement while we figure out how to fix the stock launcher.
Not working:
All video playback: Qualcom removed all video support for ARMv6 devices in JB
The next releases will contain a fix to this
ADB over network: Next release will contain a fix
Radio: I have no idea when we can fix
More as it comes
Can you explain a bit more?
I'm working on a GNow fix ATM
Well, when I flashed it, I booted up and when I got to the standard new phone welcome screen, I got a whole bunch of errors saying different apps crashed such as phone.android and a few others. And yes, I wiped everything before I flashed it.
Hm weird..
I got that phone one but the phone works fine...
Can you get a list of all of them?
First of all, HELL YEAH!!! Thanks devs. :)
WiFi works for me. In fact I'm using it now. A few things...
1) got com.android.phone fc on first boot
2) Date is correct, time is not. My timezone is GMT-4 and the reported time is 4 hrs later than the actual time. This is also with the setting to use network time enabled.
3) Notification bar doesn't show widgets/toggles
Nothing else at the moment. This ROM seems pretty quick. Haven't had a chance to do much else.
Sent from my LG-P506 using Android Central Forums
1) That fc hasn't been fixed,it's normal. it's the same for us and P500 users.
2) You will have to manually adjust, another bug :/
3) Jelly bean doesn't have toggles in it.
By the way, I've began building again, a few changes have been added to the lgics githug, and Cyanogenmod has added ALOT of changes ;) Will let you know how it goes.
I installed this rom and every second it popped up that com.android.phone closed. I am on rogers and am in a non service area if that helps.
I just tried downloading and it gave me a 404. Just so you know Oathkeeper. Downloading from Rashed's link.
Ian Breeden
