[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
Re: [ROM][July 19, 2012] AOKP Milestone 6 [RC][Nightlies]
That would definitely be the issue. Flash it again and you will be very pleased.
Well I reflashed.on the replacement and no random reboots yet.. I was pleased with the.battery life until I restarted.. it went from 50 to 20.. also ran into a 4g disconnect problem I ran into with the xda versions.. I think I had mentioned it before. The 4g switch becomes grayed out and stuck on turning on and status says active or idle and only 3g works until phone is rebooted.. screenshot attached. Don't know if this is something that can be looked into.
Attached is also a screenshot of how my battery dropped off with the restart.to get.4g back. Is this normal? This is a brand new battery..
Anyone having issues editing contacts.
Or
Has anyone tried running a different launcher such as the golauncher
Sent from my SPH-D710 using Android Central Forums
I have rc4 with simple swagger theme installed from the market. Got to say all is running beautifully delicious. Thanks for all of your hard work dark
sent from my BAD A$$ Epic touch
Reactions: Dark_Knight2
Or
Editing contacts works fine as for using a different launcher.....i only recommend 3 aftermarket launchers. CM9 Trechubet. Apex. And Nova. Go launcher or any other non ics launcher is not recommended.
Reactions: elport
Have you heard of any others that might come with folders for apps?
Alright. I got a new nightly. There was a couple of new upstream commits but mainly bugfixes. We love bugfixes :p I moved the upstream bugfixes to RC5 and the latest cutting edge stuff to the nightly. Im taking a new appoarch with the nightlies. Its now going to be AOKP/CM9 Hybrid. The RC5 will still be AOKP At the core but with some upstream cm9 fixes. I also added a new kernel for both the RC5 and nightly.
Ahhh crap. New releases.
Muuusst resiiist........nooot stroong enouuuugh
:banghead:
Lol
Thanks Dark! :D
Re: [ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightli
Thanks so much dark!
Downloading rc5 now after using the xda build for a while now.
i feel so underground :)
The last time I flashed this all my apps that were moved to the SD card would disappear on each boot and I'd have to reinstall them and move them to the SD card again. Is this a known problem?
Sent from my SPH-D710 using Tapatalk 2
Simple cure for that issue is dont save them to your sd card. Apps are not meant to be run on the Sd card.
DL RC5 right now and I'm excited. Chris41g updated his kernels so now WiFi works great. Any major changes/fixes I can expect to see in RC5?
Thanks so much for this release!
Status
kingteekay
