[ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightlies]
Status
Not open for further replies.
Re: [ROM][July 23, 2012] AOKP Milestone 6 [RC5] AOKP/CM9 [Nightli
Its a known issue with upstream cm9 and aokp builds. Ill look into it later in the week. Times Infinity is having this issue as well.
Put your phone into airplane mode before rebooting. It will fix this problem.
Reactions: elport
Do you need testers for your power save mode.
Sent from my SPH-D710 using Android Central Forums
Alright then...ill run it all day tomorrow to see how it handles a work day. I might try your RC5 tomorrow night...and see if it still does it.
Sent from my SPH-D710 using Tapatalk 2
Is it safe to backup a nandroid on rc4?
can't get that boot animation to work. i open es file manager and go to system then media. i delete the bootanimation.zip file there already then i hit up and hold the bootanimation i DLed and move to system then media. cant get it to work
Does RC5 or any build really use the standard sprint proxy for 3g and 4g communication? After trying to set these proxies to 0.0.0.0 to get better speeds I cannot edit the values (modem error) I know im using the right MSL code.
I am able to view settings and the proxy values say "not set". I'm not sure if this is because they are set to "0" not set at all. or set to the stock sprint proxy and I cant see that because of the MSL code.
FYI this is with the recommended modem
Thanks!
wait, scratch that. i got it going. thanks Def3nder. it is really cool
I can't kill my battery. Best of any ICS rom I've tried.
Well yeah 3% after 27 hours and 3 hours of screen time is pretty darn amazing. I'm running this app to try and squeeze out the last bit of juice before I charge lol.
And you are running aokp milestone 6 rc4. I am glad to hear it. I will see what I can get tomorrow at work.
Yeah rc4. For the first couple of days I let my battery fully die before charging and once its charged to 100% I leave it charging for another 2 or 3 hours just to make sure it's at maximum. I also turn off the led notification because I learned it keeps the phone from sleeping. I never really have a need for it anyway. I leave wifi and gps on all day.
Reactions: Dark_Knight2
Rc5 is running so good so far. Camera on rc4 was buggy and seems to be fixed so far with this rc5. Thanks dark.
sent from my BAD A$$ Epic touch
Where did you change your led options?
RC4 to RC5 has ALOT of upstream bugfixes.
Reactions: patrao_n
How do you build from source? I'm put Samsung official kernel source into /home/rnorris97/android/system/kernel/samsung/epic4gtouch and everything but when I try to build with make -j$THREADS bacon, it runs for a while then I get :
*** Can't find default configuration "arch/arm/configs/cyanogenmod_epic4gtouch_defconfig"!
make[3]: *** [cyanogenmod_epic4gtouch_defconfig] Error 1
make[2]: *** [cyanogenmod_epic4gtouch_defconfig] Error 2
make[1]: *** [sub-make] Error 2
make[1]: Leaving directory `/home/rnorris97/android/system/kernel/samsung/epic4gtouch'
make: *** [/home/rnorris97/android/system/out/target/product/epic4gtouch/obj/KERNEL_OBJ/.config] Error 2
Any suggestions. This is for a CM9 based ICS rom. I already got everything else right except for my config file. :mad:
You need to pull the epic4gtouch aosp code from http://github.com/chris41g
Status
