Shinkenred
- Mar 3, 2012
- 322
- 19
- 18
Re: [ROM+Kernel][CM-11.0][4.4.4][OS2SD/internal]bigsuperROM-thunderc-4.4.4
*goes through wipe process yet again* ...wait a minute, what the deuce!? Whoa, how did I NOT notice that the "basic" wipe in TWRP doesn't even touch system!? Okay, let's try it manually via Advanced Wipe. System (and everything Basic takes care of), check. Flashing...and...success!! Everything flashed!! Reboot system...and...it appears to have booted up fine!! Wait...had a "process.acore" type of FC error, but everything seems fine. Checking partition info...System indicates 150MB/158MB! Gonna have to download a file manager, but that's okay. Gonna let this beast roll for awhile in order to see what happens from here.
...wow, that IS Hacker's Keyboard. Whoops...thought it was the stock Android keyboard at first, since it looked so much like it.
Hmmmmm...AndyOpie150, I think I'll make a backup of this later and go through the process again with BeanWhiz, this time making sure that system gets wiped as well (whether I use TWRP or revert back to skinbark's CWM)...perhaps that was the underlying problem in that case, too.
The things.
First, you're wiping system first?
