economichitman
- Feb 20, 2011
- 144
- 18
- 0
Same problem here but Dolphin Browser HD works perfectly with no issues and to some may even be better than the stock browser.
I was using that a while ago, I'll give it a try.
I upgraded to the most recent CM a couple days ago, and I just ran into a problem. For some reason, it's not letting me edit any of my screens anymore. When I long press the screen, it vibrates, but that's it. Nothing comes up. Help?
I am currently running B/S IHO 10/4 and want to update to 10/17 tonight. I have just been wiping cache and davlik and then running wiper, but was wondering if I should to the factory data reset through clockwork recovery mod on boot recovery? I haven't been doing this b/c I was unsure whether or not I'll be able to flash with cwmod afterwards?
Oh, one more question. Are there any other themes besides Green Machine? And if there are, where can I get them?
Just out of curiosity, what happened to blarf's kernel? I notice the builds are using Bob's kernel now. Are there any differences? Is blarf still developing his kernel? Sorry, I'm confused!
If you are just installing an update of the ROM all you need to do is wipe cache and davlik, then flash the ROM update. You should be good to go after that. Of course always do a backup first before you do anything just to be safe. Doing a factory reset from within the recovery is not necessary if all you are doing is flashing an update but it won't prevent you from flashing in the future should you choose to do so.
Question: before I updated on bobzhome my picture messaging (sending and receiving) was working fine. But now I can't download picture messages received and pictures wont send out. TIA
Anyone else having problems with setting the brightness? Auto brightness option disappeared... brightness level keeps resetting. I put the brightness level bar up to 100% then press ok. About 5 seconds later it just goes all the way down to lowest level. Im on latest Mirage.
I noticed that the sound and brightness widgets in the status bar are not working. The bugs come from the CM repo. You can go back to 10162011 build which does not have these problems. I will post another build when these bugs are fixed.
10162011 build
10162011 transparency theme
