Sound and brightness widgets are working fine for me. Have you adjusted the settings for those widgets to include the levels you want? It appears that the defaults are to have no levels set.
~Azrael's Kiss~
Brightness and sound work for me on latest mirage also, I am having problems receiving mms also, but I can send them no problem, my wife has the same phone and can send pics to everyone but me. I will try backside and harmonia and see if I still have issues
k, you say the 101311 build is when mms stopped working on my rom. Can you or someone else that is currently have issues with mms on my current builds, please do a quick flash on this 10/10 build: CM7.1.0-VM670-BobZ-NH-101011.zip to see if they are in fact working.10132011
I am using link2sd to link/move my apps to my second sdcard partition, but i came across a problem: I currently have over 75 MB of space, as pictured below, BUT i can't install any more apps for some reason
Click to view quoted image
When I go to the Market, this pops up:
Any help would be greatly appreciated ^_^
Sent from my LG Optimus V running Android 2.3.7 on Tapatalk
So many roms! Idk which to choose from!
ICS lockscreen icons, if anyone wants them. To install, flash the zip file from recovery. Credit for converting them from hdpi to mdpi goes to boykioy.
I'm new to IHO after using Harmonia for some time. I've installed the latest MiRaGe and find that if I plug in the charger while the phone is off, it turns on automatically. I Can't find a setting that will allow it to remain off while charging. Is this common to all the IHO builds? Any way I can plug in the charger while keeping the phone off?
What I mean by quick flash is:
1) backup current rom
2) wipe/format everything EXCEPT sdcard
3) flash rom only
4) test mms
5) restore backup
Thanks for the help!
