Loving Mirage so far, with two exceptions:
- Battery drain when idle is about 5% per hour (vs 1-2% in Harmonia).
- Bluetooth inconsistently working.
The battery drain I can live with so far but probably not when traveling. I charge in my car to and from work so I get a good 80-100 minutes of charging a day that way but it's a lot less convenient when traveling. I'm curious about the Wifi sleep policy setting under GB. Is it still considered best practice to leave it set to "Never" or set it to the default? I ask, in part, because my Nook Color running CM7 has excellent idle battery life but the Wifi sleeps when the display is off; OTOH it doesn't sync anything until you turn it on (which would be really undesirable on my phone).
EDIT: Bluetooth issue appears to be resolved. The problem seems to have been related to using Winamp for media. Uninstalled Winamp and used the stock Music app it it works fine. As a bonus the Camry now shows the track number and title instead of "Streaming Audio".
The Bluetooth issue is a big one though, it may cause me to revert to Harmonia/Froyo
I'm able to pair with my 2010 Camry head unit, phone audio works, media audio does not. On the phone side of things everything seems ok. When the Camry connects the phone starts playing (the widget button updates) but I can hear no audio. The volume and track changing buttons on the steering wheel have no response most of the time. For just a few seconds after the phone starts playing the volume buttons respond but there's still no sound. Just to be clear, this same headset works 100% fine in Froyo (stock and Harmonia).
OTOH my Plantronics BT headset is working fine, so it appears to be specific to the Toyota unit.
Is there any work happening on the BT front in CM7/IHO, or any known bugs? I'm not sure how I can help troubleshoot this but I'm willing to.
