[ROM+Kernel] Inferior Human Organs unofficial CM7.1
I used to have the screen lock pattern set up for security, but since the 12212011 upgrade, I get the ring then the pattern. How to disable the ring? Having both is annoying.
One more. Each time I reboot, I have to go to Settings>Language and Keyboard>Swype so it's enabled. I imagine there has to be a way to enable it to startup at boot, but I cannot seem to locate it. Ideas?
I also saw when Leslie posted here about a new Harmonia 2 build and Downloaded it too. The post here and on the Harmonia thread were shortly removed so I've been waiting to try anything with it. she removed it so I'm sure there's a good reason.
P. S. Merry Christmas Eve Everyone!!
I'm glad I'm not going crazy and someone else saw it also, and merry Christmas to you to
Yes, I posted a build, twice.
I removed it because it was having issues, which I think are related to the build prop. A lot of apps were not showing up in the Market and Mybackup pro was having issues because of it. It won't hurt anything if you run it, but it won't run properly.
As I said in another thread, I updated a driver and it messed up my system so I am stuck reloading today, but it is very close to being done.
thank you for confirming I'm not losing it
Merry Christmas!!
Harmonia 2!!!!
My sincere thanks to Mrg666 for his help in making this happen.
Harmonia_2.zip
Md5: c892739b4da0dc5c8f432796c2dd8605
My advice is wipe everything and start fresh.
Support for H2 is provided here, NOT in the Harmonia 1.7 thread. *Note* IHO 2 has it's own thread now.
Couple things...
You do NOT need Gapps.
Uses stock GB Launcher.
Includes Email, Gmail and Market.
All included items are up to date.
This is basically a stock GB factory style rom, similar to how Harmonia 1 is a tweaked stock rom. However, it is still built from IHO.
Removed:
ADWLauncher.apk
Androidian.apk
AndroidTerm.apk
CMStats.apk
CMUpdateNotify.apk
CMWallpapers.apk
Development.apk
DownloadProviderUi.apk
FileManager.apk
FM.apk
Livewallpapers.apk (Live wallpapers still work, just none are included)
MagicSmokewallpapers.apk
Protips.apk
SpareParts.apk
VisualizationWallpapers.apk
boot animation
wallpaper
languages other than us english and spanish
Edit: Added to Github page.
Setting it up now. Seems very speedy. More excited to see if it fixes my MMS issues and improves my battery life a little. Thanks!
Im on my way to test it LeslieAnn. Thanks for everything and of course everyone else in the IHO family ... Merry Christmas to all :p
Is it possible to dual install roms at all like operating systems on a computer? i wonder if this is at all possible, like having a bootmenu that allows you to choose which installation to start in, might make trying different roms quite painless, then you can just delete the old one if you like the new one better :P
Merry Christmas!!
Click to view quoted image
Harmonia 2!!!!
Harmonia_2.zip
Couple things...
Removed:
ADWLauncher.apk
Androidian.apk
AndroidTerm.apk
CMStats.apk
CMUpdateNotify.apk
CMWallpapers.apk
Development.apk
FileManager.apk
FM.apk
Protips.apk
SpareParts.apk
boot animation
wallpaper
The clock on the status bar is 3 hours ahead. When i go to Date & time settings it shows it correct.
annahernandez51
