[ROM+Kernel] Inferior Human Organs unofficial CM7.1
Nice ^.^ the only thing i overlooked was that this probably kills your internal storage... i mean after the operating system, you throw angry birds and maybe 5 other apps on your phone and its damn near full already :P
Oh ive been meaning to ask, on the IHO rom, and also on the harmonia, theres a "theme chooser" in the home icons. I have downloaded one theme called Cyanbread and it allows me to choose between the default and the cyanbread using the theme chooser....
now, this is different from using themes in ADW launcher, so im wondering how do i just get themes for this theme chooser? do i have to look on the market for just "theme apps" ones that dont require launcher applications?
Mainly im just trying to change the way my status bar looks, IE the color mostly. thoughts?
The clock on the status bar is 3 hours ahead. When i go to Date & time settings it shows it correct.
You got me on that one. I suspect it's more your phone than the rom though.
Themes will possibly work, but it will not theme the launcher.
If you want to theme the launcher, re-install ADW.
Underneath it is still CM7, it's just stripped down to be more of a pure GB experience.
Taking out the theming system will more than likely cause force closes and create issues, so it was left in. Besides, there is no point in removing it. I try and leave your options open, but remove as much as I can.
Statusbars can be tweaked in UOT Kitchen (Google it) or with a theme I would image. I don't use them.
Your looking for ADW themes?
You should probably theme your status bar in UOt to your liking, or if you like ICS, Zdunex's ics theme.
Are there significant differences in the kernel that the iho cm7 builds use and harmonia's kernel?
I'm running latest backside build and just was wondering. If I decided I no longer wanted the green machine theme. Could I wipe cache and dalvik, reflash the rom but leave out green machine theme? Or do I have to do a complete wipe?
Just wipe the caches and reflash the rom will work just fine
Reactions: thewraith420
Harmonia 2.0 MMS not working.... came from aosp cm7, full swipe and when it booted it all looked the same it looks like you just added sound recorder
Sound recorder was left for underlying reasons, some other things work off of it.
Same with screenshot, there is an entry for it when you use the power button, which would have broken that, so it was left.
Reactions: notufatjesus
You can find plenty of themes for the theme chooser here: http://forum.xda-developers.com/showthread.php?t=1167075
Sent from my DROID BIONIC using Tapatalk
It should work fine, just be sure to wipe Dalvik cache (in advanced) and you should be okay.
Worked out great! I did a full wipe just for giggles and almost everything works great! :)
However. I have no Deep Sleep with wifi on, though it does work in Harmonia 1.x. Confirmed with CPU Spy. Did I miss something?
Just did a full wipe and install and then restored my apps, and everything works great! The only thing is when I go to the music player it doesn't recognize WMA files which IS A bummer as Harmonize 1.7 didn't have a problem with them. is there a way to fix that? Or do i have to batch convert to mp3 then?
Thanks for a great GB ROM! :Dr
fulapmu2
