[ROM] midNIGHT ROM v4.2 (BYOR Edition) CW3 Redirector/EXT4 and CIQ Removed 3/9/2011
ptfdmedic,
How hard would it be to get the blue circle icon 1% batt mod in a file by itself, without the slide lock and dial pad?
I have looked on your blog, tried several there and searched the forums, can't locate it.
Thanks,
Bre2tSco2t
Here is the exact Blue Circle Battery Mod from midNIGHT's theme. I pulled it out for you, minus the theme/lock screen & dialer pad,
Blue Battery Mod
@ptfdmedic, hope you don't mind. :)
Reactions: Bre2tSco2t
Blue Battery Mod
Thank you so much, I really like this.
FYI - I did a CW backup. Was playing with an app that put different bat mods on. Then when I loaded this file, my phone turned into FC nightmere.
Restored my backup, then loaded your file and all is good. (Incase others have problems)
Thanks again.
is it possible to get the AMLauncher for this rom? its really about the only thing i'm missing for complete rom bliss. I miss the battery life of trulyepic rebirth 1.2 but i've been a longtime fan of midNIGHT so i'm back
Just installed Midnight 3.0, so far looks real nice. It's the first custom rom that seems better than stock in every way.
One bug report:
I've been getting a lot of FCs from the MTM Gingerbread module. Seems to happen when I rotate and open keyboard.
I've been trying to reproduce this, I can't seem to make any FC's happen. Opening and closing keyboard while rotating from portrait to landscape. All is fine.
Yeah, it was happening to me over and over, but now I can't reproduce it either. If I figure out exactly what conditions caused it I'll let you know. Regardless, it seems like a really great rom!
i am having some issues syncing contacts and pictures via facebook for some reason. I dont know if this is specific to this ROM of if FB is having some glitches.
FYI - i havent every had issues syncing i dont have any settings off.
I've got the mtm fc's too. Not a big deal just annoying to get the popup. I've been loving this rom since v2.4!
Sent from my Epic 4G using Tapatalk
I have the occasional MTM FC as well, but not consistently, and a quick tap of the button takes you back to normal screen, so not a big deal in my mind... that said, I am having a GPS issue out of nowhere, that I did not have on prior versions of this ROM... GPS seems to be working, as I fired up GPS Test and it connected to 8 satellites yesterday... and Sprint Navigation seems to work OK... but Google Navigator does NOT work for some reason... it boots up, and then I get a grey popup box saying it's checking for availability (of GPS signal I assume)... this box never goes away and my phone eventually goes into hibernate... anyone else having an issue with Google Navigator specifically? Thx
I downloaded the AM Laucher in Addon's from last page, but it does not have the
same actions as the launcher in TER. Is there a setting or something I'm missing or
just unique to his rom.
I just downloaded this rom to try from TER, love tht one. I do have better quadrant scores, a couple of forced closes on email (which I don't use). Everything loaded up fine, am going to play with a couple of days to test battery. Its getting eaten up, but that is from loading, booting, and reloading, so will give a day to settle in. But good chance I will go back to TER, its just so smooth, simple and stable.
The AMLauncher in midNIGHT is slightly modified. The visual rolodex look in the apps list had been removed.
Sent from my SPH-D700 using Tapatalk
Is there a big difference between this ROM and TrulyEpic Rebirth 1.2?? I just installed that today and I really like it.
midNIGHT is fairly stripped down just like TER. They use the same launchers (midNIGHTs is modified slightly).
Probably the biggest difference is midNIGHT is using some newer tweaks and coding that is giving faster Quadrant scores over TER but honestly between you and me I really didn't notice to much of a difference. They both perform well and are very dependable ROMs.
Got my 3.0 set up but notice the ASOP email is still plaguing my Epic. Because this was early on in my build up, I just reflashed 3.0 ROM and the email program went away. (also never saw a place where I could adjust any cache options, etc.). The Black Dialer will not accept the tap, push on the end call button at times either. Also, before I noticed the Gingerbread keyboard was the default, I flashed that but it seems to be working fine. I'm guessing this ROM will be my daily user until somebody get the official 2.2 and (2.3?) begins tweaking the released Samsung code. I'm waiting to theme my phone because I'm not sure if I can theme another theme over the first one, so I'm waiting until I learn more.
I'm getting some more 32GB SDmicro cards to be able to exchange without losing what I have on one while I experiment on another. Ya! to the OP.
midnight v3.1 is out, should be on the same link. Its a little snappier if you as me, with a few more themed apps. I havn't had any problems so far.
midNIGHT 3.0 was already blazing along, couldn't imagine it getting quicker... Thats cool.
According to the change log for v3.1 when compared to v3.0 it appears that no speed enhancements were done, just some changing around of apps and storage usage. If you were coming from v2.9 to v3.x then yes things would seem quicker because there was some new coding resulting in some noticeable speed enhancement.
achongpius2022
