[ROM] midNIGHT ROM v4.2 (BYOR Edition) CW3 Redirector/EXT4 and CIQ Removed 3/9/2011
my phone has been FC'ing swype and messaging all morning. Was working fine last night then out of nowhere this morning i've been getting FC on phone, messaging and keyboard. any hints? i didn't install any other apps yesterday.
I had this issue too. I reflashed the ROM but made sure to wipe data 3x along with caches and its no longer FCing skype or messaging. Good luck!
When I flashed midNIGHT v3.0 I didn't realize until afterward that it had this feature built into it and I did my normal 3x wipe. I never had an FC's while running it for a few days.
Take that for what its worth.
I did that. And it was working for a day. Now it's doing it again!
If your doing any restores of data/apps that could very well be where your problem lies. At best I would only consider data only restores if you in this situation.
Guys I posted a tutorial on the blog. It explains briefly how to add apps to the BYOR midNIGHT ROM (or most other deodexed ROM's) prior to flashing....
I hope this helps. I have a long wait today so I'll try and check in from time to time.......
Sent from my SPH-D700 using Tapatalk
Reactions: nigma2u
3g not working right
How you doing. I recently rooted my phone and am on 3.0.0.5 with midnight 3.1 and think it updated to 3.2. It say that in the phone midnight 3.2 How ever when I'm on wifi it is spectacular as well as 4g, never seen any phone load pages so fast, but when in 3g it runs slower then before and pages take a while to load. Sometimes It does'nt show no bars for service. Did I do something wrong or is there an option to fix the 3g issue. On wifi and 4g I have benchmarked up to 2113 and with 3g the most I've got was 1723. Still love your work and just wanted to know if I did something wrong or if that's how its suppose to be. Thanks
That's a typo in the build prop....
Love this rom.. battery life is great on my epic.. was running truely epic.. but the battery life on it wasnt great... looks like i found my rom im gonna run for a while..:)
Great ROM. I was FC'ing a ton with 3.1 and 3.2, but finally just did a total wipe 3x like some people suggested. Rocking 3.1, because the 3.2 calendar doesn't have highlighted addresses or phone numbers which doesn't work for me. I do a lot of driving so being able to quickly select an address from my calendar and have it go nav or maps is essential. Is there a setting for that or is it just the nature of the beast?
3g still not working
I've done wipe 3 times on each and reflashed. wifi and 4g work but 3g works very slow. slower than the stock. Am I doing something wrong. thanks
Hmm I've been wanting to try this out but each time i flash i get, not force closes, but vibrations everytime I try to click on anything followed by the phone turning off. I then have to Odin back. I wiped the cache, factory wiped with CWM3 and cleaned the Davlik cache 3x each. I wondering if there's something i've been glossing over?
Loaded up fine, but I'm having trouble locating a download for the stock email app and messaging app. i've installed everything from the blog that says "stock", "samsung", and "3rd party" .zips .....and I can't get K9 to work right.
....thoughts?
....thoughts?
Stock DK28 Browser
Restore Bubble SMS also stops SMS notification if you use Sprint voicemail
Are you getting FC's with K9? If so try going into CWM and select Fix Permissions.
I've had good success with flashing my first rom TER 1.5 so I thought I would give this one a try. I downloaded v3.3 zip last night, backed up my current TER 1.5 set up. Cleared cache, data, dalvik, everything 3 times, installed midnight 3.3 with no errors, and started getting force closes on the initial google set up. Couldn't even get into the google login without force closes. So I fixed permissions in CW and tried again with the same result. I think cleared everything again, and re-flashed from the beginning. Same result, am I missing something here?
The zip file I downloaded checks out with no errors.
Currently I've restored my TER 1.5 and am up and running again but I thought I'd check before I give it another go.
Tiokujha
