[ROM]MIUI GingerBread Release5 4.26.2012 ZVD
Re: [ROM]MIUI 2.3.7 Release2 3.30.2012 ZVD
UPDATE:
OP updated with release 2.
browser works, CM7 camera included for time being, themes (only icons) can be applied - see post 2.
awesome, by the way have been running this ROM for a couple of days and have had 0 issues so far, just wish it had a working camera, looks like you might of repaired that with this update, downloading now.
THANKS!!!
THANKS!!!
camera worked for me on first release
Sent from my A100 using Tapatalk
So does the second release have no camera? And what about installing themes.. is it safe to use the app?
Extremely loving this rom btw!
Really? it frooze the first time and kept saying 'can't connect to camera'. I'm wondering how it worked for you.
Did you do anything to make it work or it just worked?
yeah, it was working last night, i was at a party and took several pictures. funny thing though, now it's doing the can't connect to camera lol
it's finicky i guess then lol
edit:
ok on release2, i pushed the miui camera app back, i did not open it. then i rebooted....now it's working fine, screen isn't freezing and settings work for it as well.
not sure if it will work for everyone but it's working for me....
Reactions: Invincible Madness
Here are the bugs I've encountered during the testing of this ROM.
The settings menus seem to be screwed up on some of the apps, Google Voice for example, and the Android Central Forum app. They are black and you can't see a lot of the text unless you highlight the menu option you want to read, which is a little inconvenient.
Second, I can get the lockscreen to unlock if I give the hardware keys a good one time mash. Just unlocks the screen. Weird.
Last of all, I can't for the life of me find the camera app on this ROM. I tried using it on an app to take a picture, and the app just crashed.
Besides those things, great ROM. Hope this helped and keep up the good work!
My issue regarding the camera is the same as yours. It doesn't even come up by holding down the camera button
I'm aware of the first one. Second, its not all the hardware keys, only the menu button unlocks the device, which I'm unable to change since there are no lockscreen settings. Third, are you using release 2? there should be a CM7 camera.
Ok, I'll look into it. Meanwhile, I'll attach the CM7 Camera to the OP. Just use rootexplorer and move it to System/app adn set the right permissions. Reboot.
You will have the camera now.
I'm using it now and love the look of it. Other than a few fc's its running great. I did notice if you try to go to about phone and then press phone status it takes you to legal info.
Had an error when trying to flash this via recovery:
E:missing file: system/media/audio/ringtones/romancingthetone.ogg
E:signature verification failed
Sorry if this has been posted before but I couldn't find it in this thread. I turned off signature verification and it flashed ok.
Alright, thanks. Seems I'm not the only one having that problem. Weird. Lol.
Keep up the good work!
One more thing. The lights on the hardware buttons don't come on...
U should make a version for zvj when it comes out
Just a thought :cool:
Sent from futuristic optimus s
If zvj doesn't flop lol
I'm not receiving all of my text messages. I know this because I check my Google voice inbox and I see them in there, but they won't show up in handcent or the included messaging app. any thoughts?
Been running your ROM for a few days now. Impressed :)
Bugs I've noticed:
  • Display drains battery way too fast
  • Launcher 7 FC
  • Some dialogues with black backgrounds make text unreadable
  • I couldn't get the camera app to work
ok wierd... i was running m/zvd on hydro and now i dont have radio.....
Bugs I've noticed:
  • Launcher 7 FC
Battery life has been pretty sweet for me, I used it a fair amount today and I still have over 40% left...I guess everyone is different though ;)
I had a similar issue when upgrading to zvh. I had to disable the Google voice and then I started receiving texts and calls again.
I uninstalled google voice, and it seems like ive been getting all my texts, thanks!
But now the camera wont install, i just get the "Application not installed" message
Ayomide
