- Jul 1, 2011
- 499
- 85
- 0
Re: [ROM]MIUI 2.3.7 Release3 4.9.2012 ZVD
MIUI v4 and dark themes would be awesome. I personally look forward to the Dark one
MIUI v4 and dark themes would be awesome. I personally look forward to the Dark one![]()
I believe AJ said that he's got the color problems fixed, he's just had problems recompiling it. It either doesn't show the app or doesn't recompile right.
I have applied themes that change the text color and that fixes that issue for me, so I was thinking that maybe we could change the default.mtz in the media folder.
Gannon, Lol, I was thinking exactly the same bro. to change the default.mtz to something that looks better and less issues.
Jason, Would love to see Black android theme with MIUIV4 icons or other icons.
Well I think I have it fixed but can't test it. Just realized its not deodexed
Sent from my LS670 using Tapatalk 2
rather than fixing frameworks-res.apk and the .odex file, don't you think fixing a theme file to fit for MDPI makes the job easier as it themes the frameworks anyway? I might be wrong![]()
Question : if this is built off of kraven 's cm7 is the coding still intact for mdpi folders or no?
Frameworks and apps are completely from MIUI.
I really want to try out this rom but don't want to jump back and forth from radios. Are there any plans in the future to make a release for zvh or zvj? I'm willing to wait but if not I guess I'll make the jump back![]()
Maybee this is a newb question, but I have the rom flashed and I am trying to go through the initial android setup and when it tells me to click on the android guy at the beginning nothing happens. He will light up, so I know that it is recognizing my finger but it will not proceed to the next step. Everything else is responsive. Thanks in advance!
I just kept pressing it for a solid 2 or 3 minutes with no luck.
