ARCHIVED: [ROM] Opti-ROM v1.1 built-in apps2sd, storage management, OCable!
Status
Not open for further replies.
Re: [ROM] Opti-ROM v1.1 built-in apps2sd, storage management, OCa
Followed all the directions, made sure i had all the prerequisites, yet.....NO Radio....Thoughts...PLEASE HELP. Did ALOT of Googling....NO help....
I noticed the link for the working GB keyboard leads to a "404, page not found error". Could you please post a working link? (Also, is the working keyboard exclusively for this ROM, or will it work with stock as well?
I no longer have a copy of it. However, it is included in the rom and can be used with any rom if properly installed.... I believe the name of the file is something simple like keyboard.apk IIRC, it was a big-ish file (around 10-11mb?)....
Re: overclock
On my Evo 3D, there is flash called The Configurator that allows under volting, as well as overclock. Is there anything comparable that will run on optimus? I know I can overclock with CPU tuner, but would really like to under volt.
H
Is there a reason why any app I try to install from Market gets an error saying the File is invalid?
I can't install anything.
Wipe your markets cache and reboot
I googled and tried that but I think I had the problem because I had no more space. After uninstalling some apps I am now able to install Market apps.
However now any new apps I install now have a Force Close and don't run. Old apps work fine.
Any ideas what is going on?
I do use app2SD and was wondering if this is causing problems?
Hi :) I just installed this rom to my husband's phone but now he can't send or receive texts. Is there something I missed?
Thanks for any help!
What baseband version does the phone have? This Rom requires ZVH.
Sounds like you have ZVD baseband.
sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
Always happy to help, hit that thanks button if I did
Guys this rom is great! I bought my GF one of these LG Optimus S used off ebay (She has never had an Android phone. And didn't want to extend her Sprint contract lol). So first thing I did was do my research and this seemed like the best option for her IMO. Something I can easily fix if it ever goes hay-wire, just boot into recovery :D Got it in the mail and I was like a kid in a candy store (I'm definitely a geek lol). First thing I did was root it then got the recovery flashed, then I flashed this rom, and finally flashed the pink theme for her. Now I'm just waiting for the extended battery I got for her since she works all day and then we will go and activate it :cool:
Extended Battery (If anyone is interested): NEW 3600mAh extended battery LG Optimus S ; Optimus U; Optimus V + Back Cover | eBay
Here's a review of the same exact battery: Extended Battery 3600 mAh LG Optimus V / U / S - YouTube
Cheers! :)
Glad to see anyone still enjoying this. :)
Status
Machetaseo
