Just wanted to check and see if anyone else can verify the bug I'm seeing? I use SetCPU still with this ROM, just to tune down the top-end to 729 instead of 748, since my phone can get a LITTLE flaky with extended use at that speed. Perhaps it's a placebo, but that's beside the point, heh. I have SetCPU setup to set 729-245 at boot, along with the governor set to "smartass". However, in the past few days I'd noticed that from time to time I'd look in and the governor was set back to "ondemand" automatically. I've finally traced it down, at least for my phone, to the act of Enabling USB Mode with it plugged into the computer, and then disconnecting. EVERY time I do this, the setting in SetCPU for governor changes back from "smartass" to "ondemand". Not a huge deal as long as I remember to go back in and switch it back, but it would be nice if anyone else can confirm this?
Thanks.
Mediafire is down. Can you upload to some mirrors?
can i dirty flash 2.2.2 over 2.2.1?
First of all, thanks _so much_ for your work with this handset!! I'm really happy with your Reborn Rom. Working with it helped me start to learn a little about some basic Android Dev projects I've been wanting to take on.
Second, I have a question for you (tried to write a PM, but i don't have enough posts). My apologies if it has been asked before, I certainly don't mean to waste your time. I did spend some time searching for both of these issues before reaching out
I've noticed that Airplane Mode is active after each reboot, then right after Airplane Mode is disabled, i get a "Enjoy the ROM" notification.
Is there a way to disable these two events? Is this a problem that may have occurred during flashing? I tried to re-wipe and re-flash a few times, but the problem persists. Any suggestions?
Airplane mode is intentional
Yep, the app is called xtr50fix.apk. You can uninstall or freeze it with titanium backup.
/system/app/TWS-fix.apk
Quickpic is nice.
EDIT: Didn't see answer....... Can someone post VpnServices.apk that works?
