ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Re: [ROM] Reborn ROM v2.2.2 - 6/28/11
I know there have been issues with voicemail not showing a notification, but has anyone had an issue where you can't delete the notification? I receive a voicemail icon and after I listen to it and delete it the icon won't go away.
LEGO Rom was based off of VC, the later version of ThundeROM was based off of VD as are Reborn and Shell ROM so they are both Sprint/LG based roms definitely.
Reading Kevins post it shouldn't be a problem to activate Reborn ROM, the fact that PRL updates work makes me think the phone has no problems accepting carrier profiles. The only thing I can think might make a difference is the Carrier Name which is currently set to Reborn ROM instead of Sprint, I know this causes issues with certain apks such as the nascar app but honestly I don't think even that would cause an issue with activation.
I could be wrong of course, but I can't think of any reason why reborn wouldn't work for activation, of course a CM based rom would be an entirely different story.
Thank you very much for the reply. It's very much worth the shot. When I post the phone for sale on Craigslist, I will definitely mention that the phone is rooted to be fair. This is the ONLY phone I have not been able to unroot and return to stock. I don't know why I can't do it. I've tried this on 3 different computers, with ADB, etc. I guess I'm stuck selling it with a custom ROM.
Use Google voice. Works without issue. Refer to this thread for proper setup or it will takeover text messages as well:
http://forums.androidcentral.com/sprint-optimus-s/102140-google-voice-tookover-my-optimus-s.html
One curiosity question that I can't seem to find the answer to. When you pull the down the notification bar and you have the tray of icons. What does the one to the far right do (looks like a left turn arrow)?
Screen rotation toggle
randyist did you try to remove username in ##3282# and then run SprintZone in order to get the phone activated?
The phone is turned off., but i want to sell it. I just want to know if when I sell it, It can or cannot be activated while leaving Reborn Rom on it.
When you say "turned off" you mean disconnected? As in no Sprint service? If it's disconnected then you can't find out unless you sell the phone and try what I posted. Make sure you install SprintZone if it's not on the ROM already.
I bought a new phone and now I am just waiting to sell this phone. It's in perfect condition..clean ESN. Thank you. I will make sure it has Sprint zone. I understand what people said earlier.. the rom is a Sprint Based rom, i guess (as Kev said THunderom, LEGo, etc.are based on that). So is sprint zone installable now that the phone is not going to connect to the network until somebody buys it from me and activates it?
This rom is awesome! It's working great, easy install too!
Thanks a lot for this awesome rom!
EDIT: The only problem I have is that it reboots itself every now and then. Any ideas?
Thanks!
Generally, that means it's overclocked too high for your phone. Download one of the many available overclock apps from the market and turn it back down to the stock 600. If you have no more reboots, then you can start slowly increasing the speed again to figure out what your phone can handle.
Reactions: blackbyrd84
Have been using this rom since released and am a very happy camper. Thanks again. Hopefully enough of us have donated a nice amount for all the hard work.
Oh yes, the community has been more than generous :) I don't do this for the money, but having some extra spending cash is very nice!
On another note, v2.2.3 is out. Very small release. I do need somebody to test VPN for me though, I was not able to test my fix.
Enjoy!
I tried upgrading to .3, wiped the caches and flashed, and everything booted up fine. However, I use link 2 sd, and when I tried to set that up again it froze on boot (after the reborn logo).
I went back to .2 for now, will probably try wiping everything then try again.
Just wanted to give a heads up.
Re: [ROM] Reborn ROM v2.2.3 - 7/17/11
I did the upgrade this morning. Did a complete wipe. Battery life seemed to go down. Maybe its just me.
Status
Pogojeal
