ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Anyone having issues with the wifi hotspot? Every time I try to turn it on, it kills the 3g connection and I can't get it back unless rebooted.
*edit
it crashes when i enable hotspot, give me a stop error. then disables 3g connection.
ForBetterOrForWorseROM
;) Since this is now our only option as all the dev's are working on this singe project. Can't wait to try this out! Keep going guys!
Edit: Guess I was too late to make a suggestion... Good luck to all those that made it in the poll.
.... :confused: FBOFWROM ... would have been a great premise. But def would of been long winded dontchya think? I had serious considerations of suggesting Prince. But I probably wouldn't find many people with my sense of humor.
I could go with FBOFWROM. It's fitting I believe.
I ran in to a slight problem this rom wont let me install titanium back it asks for super user permissions i click allow then it force closes and wont install any ideas?
It's the app, Joel is working on it. You can download the pre-update version from his website which works.
Not ROM related.
If you Uninstall and install right now it works?
No need, check the market comments ;) also confirmed with Joel. The apk below is pre update and will work.
http://www.matrixrewriter.com/android/files/TitaniumBackup.apk
The apk linked above is directly from Joel so no worries about Chinese viruses or anything.
Edit - got some more info. If you have TB installed then update your fine. If you try to download it brand new from the market it will force close so...
1) download and install apk linked above. Open app and give root permissions
2) go to market and accept update.
You'll be on newest version with no FC's
Edit #2 - Titanium in the market is updated and no longer FC's
Interesting, because I just reflashed NamelessROM (been messing with OSCC) and reinstalled Titanium from the market. FC immediately. I dunno why I was able to install it (and use it) from the market earlier.
Reactions: jd55555
I'll bet your download earlier was pre-update now It's post which is why you got FC's. At least the workaround is fairly easy lol
Reactions: drewwalton19216801
I know its been said before. But crap this battery life is awesome. I didn't have issues with TR but this is even better. :-)
Sent by Tapatalk ----- Optimus s
Exchange Email
I love the ROM so far. THANK YOU!
I am having a problem with my exchange account. It worked in ThundeROM, but it won't setup on Nameless. I both restored my account from Titanium and cleared email settings and entered my info manually. No error messages, just won't connect. Has anyone setup exchange email? I should mention I have also have flashed the ROM twice just in case.
Everything else is working great, but my exchange account is a must have. Any ideas?
Also: I tried K-9 mail and when setting up exchange, I get an I/O error. I'm not sure if that means anything.
I have my exchange account setup. Email, calendar, contacts all no issues. If you're sure you're setting it up properly, you might want to work with your IT department and determine what policy changes they made.
The fact k9 and stock won't work tell you It's either a setup issue or a technical issue, not a ROM issue. K9 is It's own apk, which we haven't touched, with It's own communication method to your company exchange server.
Status
jmarshallcleaning
