ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
is it suppose to say nameless rom in the build number under settings about phone? mines says thunderom-v1.6.2 for some reason, android version 2.2.1
I don't know, did you follow the steps correctly and wipe everything before you installed?
In response to those that were talking about the keyboard, I love this keyboard because of the T9 functionality. I swipe left to switch between T9 and and QWERTY.
Did you flash any build props?
nope just flashed the nameless rom and noIQagent.zip, was i suppose to flash a drop? its so weird, its running nameless flawlessly but it says thunderom on build number and android version 2.2.1 , i was on 2.2.2. b4 for the flash
Did you happen to flash NamelessROM on top of a VC build of ThundeROM? If you did that and didn't do a full data wipe, there's your answer.
hmm am i doing something wrong? i have no idea how the gestures work on the ime keyboard. when can you use these gestures? i try when i'm typing a message but nothing works...i have gestures turned on and try swyping and stuff but nothing
hmm it says when dictionary is showing so i guess if i knew exactly what that is then maybe problem solved?
i had the VD build and the latest thunderom installed but i did a full wipe before installing nameless like the instructions say, im a bit lost on what to do now lol
Just to add to the battery discussion; I had no problems with battery life until today. Before, I could get through the entire day without difficulties most of the time. Today, after 6h 49m, all of the sudden, my battery is at 3%!
What could have caused this? I played no games, a bit of texting, and 3 short phone calls. I checked the Battery Use utility, and have:
Cell Standby 39%
Phone Idle 36%
Voice Calls 16%
Android System, Wifi, Display all at 4%
I have read about some battery issues but none this sudden or extreme. The phone did feel a bit warmer than usual today, I have setCPU at 748 max, 245 min. Any ideas?
Thanks
G
Wake using home key?
Is there a way to wake using a key other than power? I seem to remember the home key being used on thunderom. I looked through the menus and did not see anything.
Thanks,
Mike
Status
Pogojeal
