ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
flash it!
results like these are scarring me lol nameless been good too me....i was about 2 flash v2 but not sure anymore
Been listening to music and texting people while I work for 5 hours straight, sitting at 70 :D
I do have data sync on. Did have Bluetooth on for 40 minutes, WiFi on some and not so good signal coverage
great rom. Thanks
I have a question on the new power notification widget, is there any way to customize it?, for example put different toggles or move the toggles around?
Also, what did the dalvik cache to cache mod do?
tried that twice...still bootlooping...FML
Boot to recovery. Wipe data, cache, dalvik. Flash ROM. Reboot system. Boot to recovery. Flash noIQagent.zip. Make sure its not the -patch file. The correct one will be on the root of the SD card.
tried to flash a theme, phone hangs at rom boot screen, also wont let me get into custom recovery... any ideas?
Read the note at the end of the flashing instructions.
Attention users: If you read post 1 and post 2 in entirety you will not have problems.
Reactions: rcandsay
i understand but is there anyway to flash a rom from my computer because i cant get into my custom recovery to reflash
There are no themes available yet for Reborn. To get back to recovery, pull battery to get out of boot loop and then reinsert it then hold power, menu, and vol. Down buttons at the same time until recovery comes up.
Sent by Tapatalk ----- Optimus s
Reactions: rcandsay
Ok, here is the power control buttons with black backgrounds.
Just Flash in recovery, no wipe of anything needed.
I can try some other colors later tonight.
You're a pro.
In the spirit of openness, here's mine. I tried to get close to Reborn's theme colors:
framework-res.apk is here. It's signed. You should be able to copy it into /system/framework/ with a root explorer, (or use terminal commands...I copied the "mount system" command from the rooting thread, mounted system as rw, and copied it in by adb shell). If it gets effed up though, your phone will hang on boot, so don't blame me if this happens and maybe make a nandroid if you want it. Sorry, I'm not good enough to make flashable zips yet.
You're a pro.
Hey that looks awesome. Do you want me to make it flashable?
Knock yourself out :D.
It was kind of fun. I had no idea apks had to be signed, and no idea what signing was... Hung my phone like 5 times and learnt a lot more about adb and shell commands....plus apparently there's a big difference using adb shell in recovery vs. Reborn...
i have the same problem as the other 2 mention, i upgraded from v1. when i flash the no iq patch, it freezes at the reborn rom screen. i wiped cache and dev cache and reflashed. i tried it 3 times, same result. if i dont flash the no iq patch, it boots up fine. any suggestions? if i dont flash the no ip patch, what happens?
it sucks to have to wipe my data and install all my apps again to get v2 to work with the no iq patch
Did you fully reboot AFTER flashing Reborn but BEFORE flashing noIQ?
The order of operations is:
Flash reborn.
BOOT INTO REBORN, let it boot entirely, give it a few minutes. Make some coffee, etc.
Reboot into recovery.
Flash noIQ.
Boot back into Reborn...
Status
cashinminutes
