ARCHIVED: [ROM] Reborn ROM v2.2.4 - 7/24/11
Status
Not open for further replies.
Sorry for the double post.... but I'm also having a problem with the data connection on this ROM, it will have the EV data when I turn it on, but then It'll come up with a message that says something about a hands-free activation, then It will say that it could not be completed and the data connection will revert back to 1x which is WAY to slow to do anything, any suggestions?
Mine does the same thing minus the hands-free activation message but it seems to always be at 1x and sometimes at EV, never at 3g like it used to be. I already updated to VD as well.
Also, everytime I reboot the phone I get a little message at the bottom saying "this feature does not support the current version", not sure why.
EV=3G=EV
1x is usually for roaming. Open the roaming app and select roam preference, then select affiliated. That seems to work best for me. See how it works for you.
Not sure if it will help, but try updating prl and profile. If that doesn't help. I would wipe cache and dalvik and reflash the Rom. You will need to let it boot all the way and then flash noIQagent.zip again.
Worth a shot I suppose.
Sent by Tapatalk ----- Optimus s
EV=3G=EV
Oh alright, wasn't 100% sure but thanks.
Done it several times with no change. How do I go about updating the prl and profile?
From the home screen, press menu, tap settings, then scroll all the way down to about phone, then scroll all the way down again, you'll see options to update profile and prl.
- Sent from my Optimus S
Have to say that I really like the work you guys put forth... very good work...
Thank you! Thinking I should dig up my wife's paypal account... (sadly, I don't have one).
Having the same problems with mine. Weird that no one else had this problem until now. Makes me think that it is a problem with sprint rather than ROM. Probably just needs a PRL update or profile update. I have tried clearing everything and re-installing with no success. Im gonna try and run some updates and will reply with any news.
Suggestion: this Reborn Rom's taskbar needs some color..we already got boot themes, dialer themes for this rom would be sweet if we had custom taskbars
Show me what you mean and I'll see what I can do.
well i dont have an example but simply just custom colorful icons on tast bar, for ex: the battery icon is colorless. thundeRom had some color in its taskbar
Oh got it, thanks. Not sure how much of a difference it did but we'll see. Now to just find my battery drain since it's now at only 6% and it got unplugged only 12 1/2 hours ago with minimal use.
for the record well at lease for me, battery life was better on nameless rom, not sure why but on nameless i went 3days w/out a charge...cant go 1 day without a charge on reborn
Yeah I'm looking into battery life improvements. I agree with you guys.
http://db.tt/VRfT0ue noIQ-reborn-bat-mod.zip
Here is a circle battery mod that I use. Make a nand and flash to try it out.
Here's a screen cap from what I'm using... (some of my icon's are from the Darkhorse theme... and yes, I'd previously asked the author for permission back when I'd thought about creating a theme... never really finished it... )
Status
ChrisAndroid
