[ROM] Resurrected Bumblebee 2.2.1 + Themes
Lol. I was confused at first too.
@Johnny, I meant anyone can make their owm theme directly from their phone. Bumblebee's Framework is preuploaded online so you don't need a PC. Anyone can make their own from mobile :)
ok
I have not tried to get the new market to work, but I think it needs a fix to the market updater.
This is really good and the market is actually not so bad even tho its the old one
Sent from my Bumblebee
Just for a change of pace I'm going old school and installing this tomorrow, I've used it before and it's always ran great. a change of pace I'm going old school and installing this tomorrow, I've used it before and it's always ran great. Now that I've find out that Firefox beta sites support 2.2 and I no longer need tether nothing is preventing me.
I can't remember but I'm not sure if SD ext was working with this rom
You don't have to re-partition, just reformat the partition to FAT32. This can be done with Mini Tool Partition Wizard. It will erase all data on the partition, but shouldn't hurt the info on the main portion of the SD card. Just to be on the safe side backup data into a folder on the computer.
Yeah, not possible, I got smashed in the head with a bat and had my laptop and one v stolen. So changing or doing anything that requires a computer is not an option lol
Im currently using Harmonia, can this be flashed over the Harmonia Rom? Or do I need a fresh install?
Sent from my VM670 using Tapatalk 2
You always have to wipe and format everything necessary for a fresh install when going from one ROM to another.
Updates to currently installed ROM usually only require you to wipe the cache partition and the dalvik cache.
If it's a generic theme from the market then yes. If it's something made in the UOT kitchen, then probably not as it's framework specific.
That girl on the messaging thread view looks like GirlGoneGamer from YouTube.
Hey, so i followed all the steps for installing ZenGarden but I still can't go pass the main menu where "Reboot system" and "Wipe/Format" are found. Sorry, I'm super new to this so step by step instruction will be really awesome and thanks in advance.
First, I don't know what ZenGarden is....
Second, the steps are pretty clear in the first post. I suggest you look at the stickies at the top of this forum before installing the ROM.
Sent from my Nexus 7
jestyulobe
