[ROM] Resurrected Bumblebee 2.2.1 + Themes
It should work for zv9, but there's always a chance it won't.
If anyone flashes it and gets a black screen, flash again because the newer OVs don't like getting flashed.
I was working on a zv9 based update, with a little more updated look, but that hit a dead end with a kernel problem. Earthnfire was working on a kernel slowly, so I can get out one more update to this before people consider it too old to run:p
I'm just wondering if this ROM works with Link2SD using a FAT32 partition. Also, this ROM was recommended because it works with the Square card reader app. More specifically, the microphone portion of the headset jack. Is that still true?
it should work with link2SD, youll just have to add the script. and yes the square card reader should work.
I'm having problems with Link2SD, trying to recreate the script. I keep getting an error message" Mount script cannot be created. mount:mounting /dev/block/vold/179:2 on /data/sdext2 failed: Invalid argument"
This message is displayed when I try to recreate the mount script for FAT32.
My Square app and card reader are working fine.
Update: I ended up reformatting my second partition and then re-linking my apps.
And you can mmake your own on UOT because Bumblebee is preloaded on there! :)
Thats wicked cool im going to try this tomorrow
my choice of roms
Gingersnap http://forums.androidcentral.com/showthread.php?t=190603
jelly sandwich http://forums.androidcentral.com/showthread.php?t=199376
quattrimus http://forums.androidcentral.com/showthread.php?t=186115
paranoid android http://forums.androidcentral.com/showthread.php?t=183592
You can if you want. There's already a ton
Btw, your tapatalk sig is obnoxiously long....
I was thinking the same thing when he posted in my thread. I didn't even realize it was a sig at first lol. Sorry Jonny it would be really nice if you could shorten it up
Tapatalk'n it from my VM670 running Kool-Blue_2.3.3_V2.1 on LS670ZVJ Baseband
For a while I was wondering why he was advertising other ROMs in my rom thread... then I realized it was his signature :p
Lol. I was confused at first too.
@Johnny, I meant anyone can make their owm theme directly from their phone. Bumblebee's Framework is preuploaded online so you don't need a PC. Anyone can make their own from mobile :)
sheiela
