[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][Sprint][JB][08/21/2012] Jellybro CM10 [Nightlies]
getting ready to flash build 5. i'll let you know how it goes in a few.
Well to be honest im not 100% on why it does it. It does it on my Nexus 7 as well. Its running CM10. Its something to do with CM.
I ran CM10 for ~10 days on my N7 and not once did it do it unless I cleared the dalvik cache manually. What CM rom were you using?!
I have also run ~20 builds of CM10 (Euroskank) on my toro and not once had it clear the dalvik cache automatically upon reboot.
Sorry bout not using your server. All i had was 3G :( I uploaded directly from phone to 4shared. 3.7 hours...what a joke :p
lol its all good man, it's just there if you need it. Use it w/e you have issues with 4share or anything else
What gapps are you flashing?
For the Nexus 7, I used only the official gapps from goo.im--that's also the package on the Euroskank site. For the toro, I use 7/23 xoomdev package.
The dalvik cache rebuilding = "Android is upgrading..."
flashed build 5 as the OP says to. It didn't make it past the samsung splash screen. Odin'ing back to el29 and will try again.
How long did you wait? JB takes a notoriously long time to boot due to a variety of checks, notably file systems.
I waited just a bit more than 10 minutes. Was that not long enough you think?
Generally, yes. My only suggest is to try a clean download--and if no dice, then there's something corrupted on your end or the rom's end.
However, with that being said, I once had a JB rom boot after 17 minutes on my Google splash screen. I kid you not.
Reactions: Dark_Knight2
Had that happen to me, went back into recovery cleared data cache and dalvik again and it eventually worked.
It my own personal build of CM10. Its never seen the light of day and it never will. Lol.
Yup, that's the standard fix for boot issues--that or a dirty flash.
Have anyone tried theme chooser on build 4 did it give you any problems?
hmm now that you mention it I cant get past the account setup.. after settings my gmail account up when its supposed to go to the home screen it doesnt.. just shows my status bar with nothing else..
no wiping methods seem to help :(
Does a reboot help?
Also, are GAPPs included or are they separate? If the latter, what package?
Status
aimalee
