[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][Sprint][JB][08/21/2012] Jellybro CM10 [Nightlies]
Does a reboot help?
Also, are GAPPs included or are they separate? If the latter, what package?
:( nope nope yes gapps were included I used 7/17
included as in i flashed them before first boot
Man I think my phone is trippin, the phone must think I'm pressing the menu button because the menu settings pop up randomly, what is that about.
is this a nightly or a test build, thanks in advance, meaning the build 5, because its not in the OP.
I get an error message that setup wizard has stopped then black screen
Same, right after you set up your gmail account right?
yeah just blacks out, funny thing is I can pull down drop screen and do updates go to market with updates but after that nothing but black screen and phone is getting raging hot.
SO far dk no problems just the odd random los but other then that its running great and smoothly
I get black screen after pressing finish setup, and all I can do is pull down the notification bar. Settings from the bar also causes a FC.
Edit: This is on build 5.
Loving this ROM so far.. no los..everything works as it should..even better then tw ICS ROMs (first time running a CM series ROM)
Had one random air plane mode happen to me ...not really a big deal tho
-Sent From My Blue Kuban Themed Tapatalk Like A Boss
that makes about 4 - 5 of us
It doesn't say on the OP so, what kernel is bundled with build 5?
yeah definetly something wrong keep getting error message that setup wizard has stopped and then black screen whether I setup gmail or not.
Status
owo Emmanuel
