[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][Sprint][JB][08/23/2012] Jellybro CM10 [Nightlies]
patch works but still can't send MMS - get error message that service is not ready will send when service is available
I can second this, also my 3g wont connect but let me play around to determine if its just a local provider issue
Build 6-3 inbound. This will be official release.
Awesome, tonight?
Also, my 3g will not connect... :/ Im wondering if anyone else has the problem or if its just service in my area... but it was connected before I flashed 6-2
found one other thing everytime I reset screen brightness it keeps turning itself all the way up and I have to turn it back down.
yea that's typical with roms, even tw roms. Try setting it to automatic and leave it there, reboot a couple times it will eventually go back to normal
Unless your symptoms youre seeing are different than what im used to experiencing. Im checking it out now
MY auto brightness works fine.
I have auto brightness checked it keeps the screen dim but the "arrow" goes all the way up by itself. I don't know if that makes a difference but whenever I check battery stats it gives me 70 - 80% usage for screen.
Status
pramanj96
