[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [PORT][2012/08/11] Cyanogenmod10 Alpha18
Can't get my ps3 controller to work with sixaxis on this rom? Is this a known issue?
I've had around 2 minutes total in deep sleep over the past 11 hours (phone has mostly been on charge). Anyone have any ideas on how to make it Deep Sleep? For me usually WiFi keeps it in 200 Mhz but it's not WiFi this time.
deep sleep while charging? no
I removed it cut it was supposed to be a pm which I'm sure you'll realize.wasn't trying to disrupt.there's nothing wrong with furthering development from someone else progress as long as proper credit is given.that's my opinion anyways....if someone else solved the issue a grudge shouldn't stand in your way.....
Sent from my SPH-D710 using Android Central Forums
Regardless... http://forums.androidcentral.com/faq.php?faq=generalacrules#faq_acrules
Reactions: tigergoalie7
Its great that you attempted to take it to pm and out of the public eye but it doesn't still give you the right to insult/name call to another member.
Come on guys.. don't start going down this path again, you've been all doing great the past few days. Keep it going.
Battery life is still horrid even with alpha 18. I have been reading about people getting an insane amount of battery life. Do i need to flash the FG31 modem or something and significantly reduce clock speed to get this or is this just something else?
Thanks.
I personally think the battery life is linked to how the rom/kernal handles the radio which also causes los. If I turn on airplane mode and wifi I get pretty good battery but if I don't have airplane mode on it plumets
Sent from my SPH-D710 using Tapatalk 2
I'm getting about 60%-70% LoS in an area I always have full cell and 4G. Running FF18.
I have no LOS (thank god) the only problem is the bad battery life:/
Also for those with loss are you using the new radio from the boost rom? This doesn't allow roaming I'm pretty sure.also are you guys using an air rave
sent from my BAD A$$ Epic touch
All the people who have LoS, Do you live in an area that has good reception on the stock rom? Ive found 95-99% of the peeps who complain of LoS live in a piss poor sprint reception area.
I am in a piss poor area. and I am on the new modem. Seems a little more stable with the new modem, but not by much. :cool:
havent had LOS since i flashed fg20 modem hours ago. Maybe i got lucky, or not. -Give it a try!
my battery is also doing fine. been on my phone consistently for the last 3 hours still have 46% left. battery wasnt fully charged either!
I am not a grudge holder at all. Whats done is done.
This is batt life and los 100% to 39 in 2 hours los the whole time. Does it still have the SD card issues
Awesome stuff, on Alpha 18 since last night. I woke up this morning and had LOS, did reboot and no LOS since, it's now 3:30PM. Camera still FC's, I'm using purchased Camera ZOOM FX. All in all great stuff and thanks a million Death_Knight2! Amazing how quick this got worked out, simply amazing. Will reply back if LOS happens, using the LOS_Tasker. Zip with Tasker btw. I will also be researching how to create a logcat after LOS occurs to throw DK and the testers way.
EDIT: LOS happened when I switched to WIFI then back to 3G data... :'( Airplane Mode toggling worked. Uploaded this via 3G.
Sent from my SPH-D710 w/ CM10 Alpha 18 using Tapatalk 2
Turn off WiFi and reboot and see if you still get los and battery drain with WiFi off.
-AOKP with a Jellybean mutation - FF18 Modem - 200dpi
Status
