[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Oh your using that one, didnt like that version ill keep using mine thanks a bunch.
Sent from my SPH-D710 using Tapatalk 2
Sorry man but I was being sincere not flaming. That is literally how I found it and it was a long time ago so I forget the exact location. I noticed the beats audio installer app didn't actually put the drivers in the system but the zip I found put them all in there. If the drivers are there, no one zip is gonna be better than another. But if you like yours better well then that's all good!
-AOKP milestone 6 - FF18 Modem - 200dpi
Re: [ROM][PORT][08/13/2012] Jellybro Euroskank CM10 [Nightly 1]
reflashing test build 3 for today.
Status 7 error continues, fix root all good.
Loads onto fancy bootscreen(love it)
takes about a min and a half the rom boots like it should
Takes a second or two for 3g to come on(normal)
signed in to my google account, takes a little bit for the signing in (normal)
Market does not want to load. (stuck on loading)
performing a reboot
went in to settings/app and cleared data and market now works as it should
testing mms... sent a pic to dk it sent immediately (normal)
testing camera app working(normal)
tested torch (normal)
downloaded google maps to test gps locked to 10 meters in 5 seconds(normal)
everything seems to be working normally
however it appears to be exactly the same as yesterdays build.
i tried everything,,,,el26 chris cwm 6 and the boots goes all the way to the su fix and i click yes than i get black screen,,, i wish i can get a video tutorial,,,,:-\
performing a reboot
Well GPS has improved. Gps was locking at 40-50meters. Now its 10 meters :) My gps tweaks work
So dk can't patch sbrissens kernel anymore, or do we have to wait for an official update?
Sent from my SPH-D710 using Android Central Forums
Well sbrissen is working on rebasing his kernel currently so maybe when that is ready we can use that. But I'm not sure about what DK's progress is on patching the current kernel.
Well mobile Odin works if you guys get terrible Los or something and are to scared (like me) to use cwm6 a lot. Loved jb but I couldn't get texts until I rebooted my phone then they'd pop up and I'd send and have to reboot to get the next, but that was my problem and everything installed well and had camera. Thank you dk for your hard work hopefully the kernel will be fixed soon because I did love it except for the texts:)
Reactions: Dark_Knight2
Non of my testers have any such issues. You are just really prone to random issues.
seems I got some more random issues exchange can't connect - won't download email, battery won't charge now. It seems my phone has more than the usual problems preventing me from enjoying this ROM.
sorry if this question was asked already but after flashing alpha18 do i need to wipe cache delvic and data? Or just install euroskank.zip afterward?
Dk bad news bro... status 7 on 8-14 build... :(
Going back to nandroid of 8-13 test build 3
it boots like it normally has have to fixroot
set_perm some changes may have failed.
Error Status 7
I tried what you did and Im still getting the same result.. Black Screen. :/
I had the same result. The installation went flawless(Status 7, Installation aborted aside). Installed Gapps. Fixed SU prompt. Reboot.
Then the splash screen comes up and boots into a black screen.
Any ideas?
DK no go on test build 5 man...same thing same story.
Hitting the sack though.... nandroid back to test build 3, with my apps and settings.
Back to the drawing board tomorrow man.
Good night,
nothingblooms
Status
No members online now.
kevin_bkt
