[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][08/14/2012] Jellybro Euroskank CM10 [Nightly 2]
ok i got that partition error when installing the kernel from the op. my phone went nuts on me so now im gonna odin back to el29 and go from there since nothing else seems to have any effect on odin..
Its not working still. I wiped everything again. I am using the cwm6
same here I tried the wipe all except data/system of nightly 1 received root error
so I nandroid back to working nightly 1 with no root error
wiped all installed rom gapps rebooted
same thing root error trying to load titanium back up
back to working nightly 1 with latest kernel from Sbrissens and its quick and working good
I even tried updating binary and trying another super user of play store same results
also tried clear data force stop and fresh boot on current super user with the :(same results
no root for me niether,can update binary..fails
Im waiting for my tester to verify again if he indeed has root access. Standby.
I just confirmed he does indeed have root access with the newest build nightly 2 in the op. However he only wiped cache and dalvik then flashed over nightly 1.
DK ive done a clean install of the nightly 2 and still no root access
Ive also installed over nightly 1. No luck.
Hey guys after testing the ROM and having root access Dk came back to me saying that you guys are having trouble.
Its not that you don't have root access. Its the superuser app. You can do one of 2 things. Download supersu from the market.
Or if you open the superuser app. Go to the wrench for settings. Then select security. Then go to automatic response and set it to allow from prompt. It will then work fine.
Sent from my SPH-D710 using Android Central Forums
Worked for me. Thank you,
i can confirm root works after setting allow in su
"Root Checker Basic" showed I didnt have root until I followed your steps..
The app now shows I have root..
I've updated my post to include your instructions
I used lowrider gapps, got supersu to update binaries, but can not download titanium to varify. Market keeps coming up with some sort of error when try to download.
(error retrieving information from server) Im on wifi.:confused:
LOS still within 30 minutes, other then that, great job. :D Also, flashed new sbrissen in cwm for all who seem to be having problems. worked fine. Tryed clearing cache on market and in recovery
Are we clear to format sdcard with this rom? I've read that this was a problem on some other roms.
Thanks....
Status
