Aha! Thanks man, sorry about that! There was not internet at this campground, let alone WiFi...it was PAINFUL!
nvm can't do that either .... is a
.tar file... rage
Op has flashable zips... follow instructions on there should get you on the ROM :thumbup:
Sent from my SPH-D710 using Tapatalk 2
ty.. OP is always my first stop on these things never know what has changed till you read... just 2 avoid question...
Sbrissens Newest JB Kernel Flashable
will that have the cwm6 in it 2 get this going? or any of those others for that matter...
and ty for the response
Yes, that is the same kernel that is now included in the rom. It is safe for flashing.
i have su access, but my superuser app is not working properly. if i set my security settings to automatically allow, my apps have su permissions but the Superuser app does not log nor notify app access (taskbar nor toast).
i was able to manually delete superuser app using solid explorer and i tried updating the app and still does the same thing. i've even used the zip file DK posted earlier and exact same results.
i also got the "partition missing" error when i tried to mobile odin into sbrissen kernel tar. so i just install the zip through CWM6 from chris41g kernel.
i also get the 4g unknown error the first time connecting. . . and oh, the only way to access the 4g settings is by pressing and hold the 4g taskbar toggle ?
dk- is there a need to update profile/prl?
