- Jun 24, 2012
- 1,716
- 1,432
- 0
Second test release booted. Just gotta fix a few FC issues.
Once you drop the 3rd test, shoot me a PM, I'm home, off work, and ready to test it all for ya!
So for the GPS, I tried the flash GB Rom/Flash back after getting a lock. Seemed to lock on fast at home. Will report back if it can stay locked on the road (crosses fingers). Haven't had too much LOS, very usable. Battery charges really fast. Seems to drain from 100% to 75% pretty fast but then 75% to 10% lasts quite a while.
Calibrate your Battery...
Can I use any cwm6 recovery to flash this??? The sbrissen kernel tells me partition cannot be found!
Sent from my SPH-D710 using Xparent Blue Tapatalk 2
What? Sbrissens CWM6 works just fine.
I tried to mOdin the tar that's in the op but it say no partition can be found!
I also tried on PC. Just errors out like someone posted a few pages back
Extract the boot.img from the .tar file. Then mobile odin it.
Thank you for shedding some light in my confusion now! Just one more stupid question ummm err how do I extract a tar. File
Seriously? I kindly asked you to remove an apk from your OP where the author said XDA exclusive only and not to distribute, yet you have it up for download on your dropbox account. Thats it. I think you're a bit paranoid if you think I'm nitpicking.Man Corrupt_Data and YeastInfection are trying to ruffle some feathers here arent ya?
YeastInfection? DO NOT PM ME AGAIN. DO NOT POST IN MY THREAD AGAIN
Corrupt_Data? You are just looking for things to knit pick with me. Ill let this slide. I know what you are trying to do and I do not find it funny.
You had me confused as well. I thought you had CWM6 on your device already and when you went to flash it it gave you that error. Lol.
download the app and run it
