[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][JB][08/18/2012] Jellybro CM10 [Nightly 3]
[APP] [2.3 and EXTSD 5/13/2011] Disable Media Scanning on Boot & Scan Media on Demand
found this link to disable media scanner
how do we disable it at boot?
would rom tool box have that feature?
thanks in advance for a great find
hey daniel4653, try one clicking ff18 stock rooted from sfhub and restoring your phone..obtain ur gps lock on that modem (so you wont have gps issues later) and then from there go into download mode and odin el26 stock tar and do your upgrading there..flash ur cm9 rom then gapps and whatever zips except modem and let it boot...
make sure you can obtain the gps lock with the ff18 modem while using cm9 and once you do, then reflahs/upgrade your modem .. this should fix anything.. i usue the calkulin format allx2 also before i flash anything
if u gon get something make sure u get it good
Just wondering why flash back to a touch wiz ROM to fix GPS when GPS status app does the job
Sent from my SPH-D710 using Tapatalk 2
Not sure if anyone else is having this issue but when I have the phone set to vibrate only I still have noise when someone calls or texts me. using Handcent for texts also.
Status
