[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Re: [ROM][JB][08/21/2012] Jellybro CM10 [Nightly 4]
Don't Think My Phone Likes this ROM.. I'm still getting LOS on fh13... any suggestions?
Didnt know that there was a new kernel out... will try and report back
I flashed the updated JB Gapps 07.26.2012 version and everything is working fine. Actually have an updated Play Market with a redeem feature for cards, other than that Goo.im stopped notifying me to update it, which was the main reason I updated. Btw DK2 said to go ahead and do it though his OP says to Flash the previous Gapps.
Sent from my SPH-D710 using Tapatalk 2
can you post the link or is it in the OP
Even if that works it sounds like a bandaid not a permanent solution.... :(
I think everyone should specify which SG2 they're reporting bugs/problems on. I read so many posts with problems but they're for the Sprint SG2 and not US Cellular (only after I double check names and reread the post). Some people have in their sig which phone they have but that'd be cool if everyone could be a little more specific. Only a suggestion, not attacking!
No word on how to use the emonji ? I searched and they said to add dictionary under the keyboard settings but there is no option to do so
Checking for sure but I think I may have fixed it.
Yes, yes I did!
Here is what I did.
Flashed Stock odin FB14 files
*228 updated prl got 3g
odined ff18 modem
cleared cfs was checked
*228 updated prl for 3g
odined fb14 w/cwm
rebooted into cwm wiped data cache dalvik
flashed aokp(3g didnt work)
rebooted into recovery
flashed rc11
rebooted recovery
flashed codename android pre alpha 3 JB
flashed gapps
no 3g....
Dialed *228 woman said successful phone said fails(like always)
showed LoS instead of rebooting phone I put into airplane mode for 5 secs then clicked it off and immediately tried google search.... wam bam thank you ma'am
Thanks for anyone who had a suggestion!
Back in the game
nothingblooms
Soo an airplane mode toggle fixed it??
-AOKP milestone 6 - FH13 Modem - Cobalt theme
with all the combined steps.... that is one of the very first things I tried when this originally started happening :P
DK, I'm running nightly 4 with the newest kernel and I'm experiencing absolutely no problems. No LoS. Nothing. You are the man. Sbrissen as well. Thank you for supplying such a stable ROM. Will definitely donate next time I get paid.:D
Sent from my SPH-D710 using Android Central Forums
I'm using vanilla CM10, but to use emoji you have to enable it in the messaging app, through settings. Then whoever you want to send an emoji to, you open up the thread, press the menu button and select Insert emojis. I don't know if this helps, but let me know if it does or doesn't.
Hey guys, is there anything we can do to bring back the gallery sync? Anything?
Status
Ninjja
