[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Its just in the "greyspace" where no notifications are, right? I see that too. Honestly I use it so little in landscape that it could have been there the whole time for all I know.
Yea i use it all the time, and know it was not there in DL09, im not that concerned about i i just thought i would bring it up and see if it was just me.
Having issues, my text messages are not coming through and going out they are blank.
i'm having the same problem despite having flashed the test 2 non-voodoo kernel. at least i think i flashed the kernel (i'm a noob to root/flashing)... these are the steps i took.
- boot into CWM recovery from CWM rom manager
- apply sdcard:update.zip
- choose zip from sdcard
- adryn_test2_0116_fascinate_nonvoodoo.zip
- +++++Go Back+++++
- reboot system now
is there a way to check if i have installed the kernel correctly? eg. settings -> about phone -> kernel version. it says that the kernel version is 2.6.69 btw..
is there anything that i am doing wrong? really want to get text messaging back on my phone :(
edit: do i need dl09 modem (i don't know what that is btw..)? i had stock dl01, rooted it, then flashed this rom and test2 kernel (or at least i think i did).
edit2: i flashed dl09 modem/radio. then reflashed the rom/kernel. everything works now! :D
Posted this elsewhere, but whereas I'm using this ROM, I thought I'd post here to let others know...
I liked the stock calculator, clock, and Thinkfree Office that came on the Fascinate, so I used Rom Manager to install them.
May I ask how you re installed Thinkfree Office, the clock, and the calculator?
Or can I request that it be put back in the Rom. As I use it to track my workouts!
I can make packages for folks...the youtube app can be fixed by clearing data, usually. Its kind of a hackjob.
Does Launcherpro have compatibility issues with this ROM? - three attempts to get this loaded has led to three different process to the same outcome - restore the backup and start over..
Have had it stop half way through the CWM loading and endup with an (out of the box 'rooted' phone'); loads up and the power button causes the phone to reboot, flashed the theme fix, flashed a new kernel, and it does not change; downloaded a fresh rom zip, cleared cache, data, and start over.. same results.
The only thing I can think of is is there a launcher conflict.. I may be way off..
im confused jaekar this rom overwrites the previous rom so what would having launcher pro have to do with anything....are you wiping data and cache from clockwork?
As you were typing your response I was realizing what I needed to do.. some days I think I have a serious case of brain constipation...
I have two copies of the ROM the one I down loaded last night is corrupt... will try again with the copy from my work computer..
Edit: Attempt 4 - fail. Got further into the process after a wipe of device and cache - installed again.. still getting odd reboot when long press on the power button. RE - Flashed the theme fix... issue still present - - Flashed Adryn kernel 1/16 - issue still there.. Guess I am wondering if there are others having this same issue and if there is an easier fix than a full wipe and reload.
cool, good luck, im off to sleep. Have a great day
Installed the rom and now I can't find the stock bluetooth voice call program. I ready liked it now the one that is on the now can't understand the voice as well
Do you have to be a member of xda to download Swype? I clicked on the link to the page "Update to newer version of Swype - Here ya go.." but for the life of me i do not see a file to download on the page :/
Status
Industrialbattery
