[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
AHA - I am having a bug with my power button. Short press, locks the phone no problem. Long press - no pop up menu, no nothing, phone actually freezes for a few seconds, un-freezes, then just reboots. Not a big deal since that is most of the time what i want it to do, but it certainly seems to be not right.
Any ideas???
Using supah clean with 12/30 non-voodoo kernel
im assuming since you're posting in this thread that you flashed adrynalyne's sc.4 ROM...did you flash either of the theme hax?
if so i would try re-flashing that, and maybe the kernel as well. you might try flashing the test 3 sv nv 01/16 kernel in the OP; its what im running currently and it works just fine.
And still having the gps issue, won't lock on.
Any ideas???
Yeah you flashed something incompatible. Flash the theme fix.
Hey question about the OP, it says we have to apply a theme hack if we want to use a dl05 theme, but what if its a dl09 theme from rom manager? does this still need to be applied, such as the theme in sonofskywalker, or can we only use themes from the jt section
OK obviously I don't know what I am doing because I keep running into the same problem. I cannot flash anything via CWM. I was told this is because we cannot use Recovery 2e or whatever so I flashed CWM via from the sticky Adrynalyne posted on the forum but that didn't do anything.
Obviously I am doing something wrong but I just cannot figure it out.
I flashed D101 via odin, updated to DL09 OTA then rooted. I downloaded CWM from the market and tried to flash the rom, didn't work, same with test 3 kernel.
I tried flashing the CWM via odin from the sticky, still same problem.
Can somebody please give me a step by step as to what I need to do to get CWM working the way it is supposed to. I thought I followed the steps correctly but obviously I have not.
Thank you.
need help with installing this rom i rooted the phone installed the rom manager flashed it put the rom on my sd card clicked the option to install the rom from the sd card. it looked of till it got to the part when the phone was unpacking the file and then in red font is stopped and said failed to open the file . I tried it like 4 times i also was going to use odin but when i clicked PDA i couldn't see the file to use with odin.. I use to do lots of rom installed when i had my droid and no problem. HELP!!!
By the way the new update SUCKS!!! gps still don't work, looks like we need to do what we need to do to get a working Phone..
Having issues, my text messages are not coming through and going out they are blank.
I flashed again with a fresh flash, wipe and clear, still no text messages are coming through . I get calls and data however.
I'm having the same bluetooth issue as decaydance99 as well.
What kernel are you using? I use handcent but I have no issues with bT or SMS. You will need a kernel change unless you are coming from a DJ05 rom/kernel.
Hey Overcomer, did you try the kernal that was attached to the original post? Bluetooth working fine for me.
Reactions: BigJB
Posted this elsewhere, but whereas I'm using this ROM, I thought I'd post here to let others know...
I liked the stock calculator, clock, and Thinkfree Office that came on the Fascinate, so I used Rom Manager to install them.
Ok, tried it... and glad I took the time to do a backup.
Like killahamsammich (really, where do you people come up with these names ), the countdown alarm is silent on the super clean rom.
Also, Thinkfree Office does not show up as an option when I try to preview a doc in email. Yes, I activated it for "this device"
and fyi - on BOTH calculators, I entered "9+6*3" and got "27"!? Really?!
Adrynalyne - have you ever seen the policy modification to remove the full battery pop up? Looking at doing this manually but I assume any new rom will wipe out the change. Does anyone even want that pop up?
Thanks
Hey i flashed the rom over the old DL09 update and everything works great.. the only problem is that my facebook sync doesn't appear to be working... for the contacts at least? any idea what the cause of this may be?
uh... because that is right?!?!? 6*3=18 18+9=27 Multiplication and then addition is the way I was taught. ;)
Adrynalyne... thanks for supporting this community! You rock!
Did you post a link to the original clock and calculator? I saw the question asked in the thread, but might have missed if you linked to them.
Thanks.
edit... just saw where it looks like the clock and calculator can be installed through rom manager. I'll check there later.
Haha, yeah me too. Doh!!
Sadly, I was thinking 9*(18), instead of what I wrote, 9+(18).
Sad...so sad. Kid you not, I got into Mensa with my math skills.
ps - Did you read my issues with the original clock on this ROM? Unfortunately, this makes the original clock a failure for me.
Which Kernel would you reccomend? Link? I really like everything about the rom and would prefer to use it then not.
I'm having the same problem. Any thoughts from our great community?
Status
Screwgoogle
